mppt-error-codes
mppt-error-codes [2017-08-02 21:55] – [Err 21 - Current sensor issue] mvader | mppt-error-codes [2023-09-14 14:07] – rvanzundert | ||
+ | Detailed error codes can be read with: | ||
+ | * Remote panel, such as the Color Control GX or the MPPT Control. | ||
Line 23: | Line 40: | ||
Line 29: | Line 58: | ||
- | Disconnect | + | |
- | If the error persists the charge controller is probably faulty. | + | |
+ | Possible solutions | ||
+ | === AC Chargers === | ||
Line 56: | Line 116: | ||
+ | Possible causes: | ||
Line 61: | Line 143: | ||
- | ==== Err 38 - Input shutdown due to battery | + | ==== Err 35 - PV over-power ==== |
- | To protect the battery from over-charging the panel input is shut down. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes reconnect the battery first and next the panels. | + | |
- | A common reason for this error to occur is that the Battery voltage (12/24/48V) is set, or auto-detected, | + | Applies |
- | Use VictronConnect | + | Please upgrade your firmware |
+ | * There is another device connected to the battery, which is configured | ||
+ | Error recovery: | ||
+ | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | ||
Line 79: | Line 240: | ||
- | ==== Err 114 - CPU temperature | + | When removing charger from such system, and reusing it in a system without BMS, that setting needs to be cleared. |
+ | __Background__ | ||
Line 102: | Line 325: | ||
- | The unit is faulty, contact your dealer for a replacement. | + | If the unit does not work and error 116 pops up as the active error the unit is faulty, contact your dealer for a replacement. |
Line 108: | Line 345: | ||
