mppt-error-codes
mppt-error-codes [2017-08-02 21:55] – [Err 21 - Current sensor issue] mvader | mppt-error-codes [2018-05-09 10:27] – [Err 116 - Calibration data lost] rvanzundert | ||
+ | Detailed error codes can be read with a remote panel, such as the Color Control GX or the MPPT Control. | ||
Line 62: | Line 65: | ||
The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | ||
- | ==== Err 38 - Input shutdown | + | ==== Err 38, Err 39 - PV Input shutdown ==== |
- | To protect the battery from over-charging the panel input is shut down. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes reconnect the battery first and next the panels. | + | To protect the battery from over-charging the panel input is shorted. |
- | A common reason | + | Possible reasons |
- | Use VictronConnect to disable auto-detect | + | Error recovery: |
+ | * Error 38: First disconnect the solar panels | ||
+ | * Error 39: The charger will automatically resume operation once the battery | ||
Line 96: | Line 105: | ||
Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. | Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. | ||
- | ==== Err 114 - CPU temperature | + | ==== Err 114 - CPU temperature |
Line 102: | Line 111: | ||
- | The unit is faulty, contact your dealer for a replacement. | + | If the unit does not work and error 116 pops up as the active error the unit is faulty, contact your dealer for a replacement. |
==== Err 119 - Settings data lost ==== | ==== Err 119 - Settings data lost ==== |
