mppt-error-codes
mppt-error-codes [2017-02-05 22:13] – [Err 67 - No BMS] mvader | mppt-error-codes [2024-02-12 05:48] (current) – [Err 54 - Inverter output voltage] guy_stewart | ||
+ | Detailed error codes can be read with: | ||
+ | * Remote panel, such as the Color Control GX or the MPPT Control. | ||
+ | This error can also occur if the battery voltage (12, 24 48V) is set to a lower voltage than the connected battery. | ||
Line 23: | Line 40: | ||
Line 29: | Line 58: | ||
- | Disconnect | + | |
- | If the error persists the charge controller is probably faulty. | + | |
+ | Possible solutions | ||
+ | === AC Chargers === | ||
+ | Disconnect all wires, and then reconnect all wires, to make restart the charger. Also, make sure the minus on the MPPT charge controller | ||
+ | This error indicates that the fan is powered on but the circuit does not measure any current draw by the fan. Most likely its either broken or obstructed. | ||
Line 53: | Line 116: | ||
+ | Possible causes: | ||
Line 58: | Line 143: | ||
+ | ==== Err 35 - PV over-power ==== | ||
+ | If you are using firmware v1.08 or newer this error indicates that the internal dc voltage is too high. This error will auto-reset. | ||
+ | Error recovery: | ||
- | ==== Err 38 - Input shutdown due to battery over-voltage ==== | + | Automatic checking of the disconnect |
- | To protect | + | This usually indicates a broken relay (sticky contact) in the AC input stage. |
Line 71: | Line 240: | ||
- | ==== Err 67 - No BMS ==== | + | ==== Err 67 - BMS Connection lost ==== |
- | The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. The charger stopped charger, as a safety precaution. | + | |
- | ==== Err 114 - CPU temperature | + | When removing charger from such system, and reusing it in a system without BMS, that setting needs to be cleared. |
+ | __Background__ | ||
Line 94: | Line 325: | ||
- | The unit is faulty, contact Victron. | + | If the unit does not work and error 116 pops up as the active error the unit is faulty, contact |
Line 100: | Line 345: | ||
