mppt-error-codes
mppt-error-codes [2017-02-05 22:13] – [Err 67 - No BMS] mvader | mppt-error-codes [2019-01-22 10:16] – external edit 127.0.0.1 | ||
+ | Detailed error codes can be read with a remote panel, such as the Color Control GX or the MPPT Control. | ||
Line 7: | Line 10: | ||
+ | This error can also occur if the battery voltage is set to a lower voltage than the actual battery voltage. | ||
Line 30: | Line 33: | ||
- | Disconnect | + | If the error does not auto-reset disconnect |
- | If the error persists the charge controller is probably faulty. | + | A cause for this error can be switching on a very large load on the battery side. |
Line 45: | Line 48: | ||
+ | Disconnect all wires, and then reconnect all wires. Also, make sure the minus on the MPPT charge controller (PV minus/ | ||
Line 59: | Line 71: | ||
The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | ||
- | ==== Err 38 - Input shutdown | + | ==== Err 38, Err 39 - PV Input shutdown ==== |
- | To protect the battery from over-charging the panel input is shut down. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes reconnect the battery first and next the panels. If the error persists the charge controller is probably faulty. | + | To protect the battery from over-charging the panel input is shorted. |
+ | Error recovery: | ||
+ | * Error 38: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | ||
Line 74: | Line 97: | ||
- | ==== Err 67 - No BMS ==== | + | ==== Err 67 - BMS Connection lost ==== |
- | The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. The charger stopped | + | The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. The charger stopped |
Check the connection between the charger and the BMS. | Check the connection between the charger and the BMS. | ||
Line 86: | Line 109: | ||
* VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, | * VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, | ||
- | Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one. | + | Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. |
- | ==== Err 114 - CPU temperature | + | ==== Err 114 - CPU temperature |
Line 94: | Line 117: | ||
Line 104: | Line 130: | ||
