mppt-error-codes
mppt-error-codes [2017-02-03 20:10] – mvader | mppt-error-codes [2024-02-12 05:48] (current) – [Err 54 - Inverter output voltage] guy_stewart | ||
+ | Detailed error codes can be read with: | ||
+ | * Remote panel, such as the Color Control GX or the MPPT Control. | ||
+ | This error can also occur if the battery voltage (12, 24 48V) is set to a lower voltage than the connected battery. | ||
Line 23: | Line 40: | ||
Line 29: | Line 58: | ||
- | Disconnect | + | |
- | If the error persists the charge controller is probably faulty. | + | |
+ | Possible solutions | ||
+ | === AC Chargers === | ||
+ | Disconnect all wires, and then reconnect all wires, to make restart the charger. Also, make sure the minus on the MPPT charge controller | ||
+ | This error indicates that the fan is powered on but the circuit does not measure any current draw by the fan. Most likely its either broken or obstructed. | ||
Line 53: | Line 116: | ||
+ | Possible causes: | ||
Line 58: | Line 143: | ||
+ | ==== Err 35 - PV over-power ==== | ||
+ | If you are using firmware v1.08 or newer this error indicates that the internal dc voltage is too high. This error will auto-reset. | ||
+ | Error recovery: | ||
- | ==== Err 38 - Input shutdown due to battery over-voltage ==== | + | Automatic checking of the disconnect |
- | To protect | + | This usually indicates a broken relay (sticky contact) in the AC input stage. |
Line 71: | Line 240: | ||
- | ==== Err 67 - No BMS ==== | + | ==== Err 67 - BMS Connection lost ==== |
- | The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. | + | |
- | Or, when the charger needs to operate | + | Solar Chargers only show this error when there is solar power available and thus the device is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. |
- | * For VE.Can solar chargers, go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | + | Solution: check the connection between |
- | * For VE.Direct solar chargers, reset the charger | + | |
- | Note that (solar-)chargers automatically configure themselves | + | __How to reconfigure the charger |
- | ==== Err 114 - CPU temperature | + | Our Chargers and Solar Chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a GX Device. And that setting is semi-permanent: |
+ | __Background__ | ||
Line 92: | Line 325: | ||
- | The unit is faulty, contact Victron. | + | If the unit does not work and error 116 pops up as the active error the unit is faulty, contact |
Line 98: | Line 345: | ||
