mppt-error-codes
mppt-error-codes [2016-12-02 15:41] – mvader | mppt-error-codes [2023-07-19 08:54] – [Err 70 - Network misconfigured] rvanzundert | ||
- | ==== Error Codes ==== | + | Detailed error codes can be read with: |
+ | * Remote panel, such as the Color Control GX or the MPPT Control. | ||
+ | ===== Error Codes ===== | ||
- | === Err 2 - Battery voltage too high === | ||
- | + | This error can also occur if the battery voltage (12, 24 48V) is set to a lower voltage than the connected battery. | |
- | === Err 3, Err 4 - Remote temperature sensor failure === | + | ==== Err 3, Err 4 - Remote temperature sensor failure |
Most likely cause: the remote T-sense connector is connected to the BAT+ or BAT- terminal. | Most likely cause: the remote T-sense connector is connected to the BAT+ or BAT- terminal. | ||
This error will auto-reset after proper connection. | This error will auto-reset after proper connection. | ||
- | === Err 5 - Remote temperature sensor failure (connection lost) === | + | ==== Err 5 - Remote temperature sensor failure (connection lost) ==== |
- | === Err 6, Err 7 - Remote battery voltage sense failure === | + | ==== Err 6, Err 7 - Remote battery voltage sense failure |
Most likely cause: the remote V-sense connector is connected in reverse polarity to the BAT+ or BAT- terminals. | Most likely cause: the remote V-sense connector is connected in reverse polarity to the BAT+ or BAT- terminals. | ||
- | === Err 8 - Remote battery voltage sense failure (connection lost) === | + | ==== Err 8 - Remote battery voltage sense failure (connection lost) ==== |
- | === Err 17 - Controller overheated despite reduced output current === | + | ==== Err 11 - Battery high ripple voltage ==== |
+ | ==== Err 17 - Controller overheated despite reduced output current | ||
This error will auto-reset after charger has cooled down. | This error will auto-reset after charger has cooled down. | ||
Check the ambient temperature and check for obstructions near the heatsink. | Check the ambient temperature and check for obstructions near the heatsink. | ||
- | === Err 18 - Controller over-current === | + | ==== Err 18 - Controller over-current |
- | Disconnect | + | |
- | If the error persists | + | Possible causes for an over-current on the battery terminals: |
+ | Possible solutions | ||
+ | ==== Err 20 - Maximum Bulk-time exceeded ==== | ||
+ | === Solar Chargers === | ||
+ | If you do see this error, then update to the latest firmware. | ||
+ | If you then still have the error, perform a reset to factory defaults of the configuration, | ||
+ | === AC Chargers === | ||
+ | This protection | ||
- | === Err 20 - Maximum Bulk-time exceeded === | ||
This error is generated when the battery-absorption-voltage is not reached after 10 hours of charging. | This error is generated when the battery-absorption-voltage is not reached after 10 hours of charging. | ||
- | This protection is default disabled in all Solar Chargers. | + | The feature of this safety |
+ | ==== Err 21 - Current sensor issue ==== | ||
- | It is default enabled on the Skylla-i and the Skylla IP44. | + | The current measurement |
- | Our advice is to not enable it on solar chargers. | + | Disconnect all wires, and then reconnect all wires, |
- | === Err 21 - Current sensor issue === | ||
- | The charge controller is probably faulty. | ||
- | === Err 26 - Terminal overheated === | + | If the error remains, please contact your dealer, there might be a hardware defect. |
- | Power terminals overheated, check wiring and fasten bolts if possible. | + | |
+ | This error indicates that the fan is powered on but the circuit does not measure any current draw by the fan. Most likely its either broken or obstructed. | ||
+ | ==== Err 26 - Terminal overheated | ||
+ | Power terminals overheated, check wiring, including the wiring type and type of strands, | ||
- | === Err 33 - PV over-voltage === | + | ==== Err 27 - Charger short circuit ==== |
+ | Possible causes: | ||
+ | ==== Err 33 - PV over-voltage | ||
This error is an indication that the PV-array configuration with regard to open-circuit voltage is critical for this charger. Check configuration, | This error is an indication that the PV-array configuration with regard to open-circuit voltage is critical for this charger. Check configuration, | ||
- | === Err 34 - PV over-current === | + | ==== Err 34 - PV over-current |
- | === Err 38 - Input shutdown due to battery | + | ==== Err 35 - PV over-power ==== |
- | To protect the battery from over-charging the panel input is shut down. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes reconnect the battery first and next the panels. If the error persists the charge controller is probably faulty. | + | |
- | === Information 65 - Communication warning === | + | Applies to the MPPT RS, Inverter RS and Multi RS products. |
+ | Error recovery: | ||
+ | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | ||
+ | ==== Information 65 - Communication warning | ||
- | === Information 66 - Incompatible device === | + | ==== Information 66 - Incompatible device |
- | === Err 67 - No BMS === | + | ==== Err 67 - BMS Connection lost ==== |
- | The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. | + | |
- | Or, when the charger needs to operate | + | Solar Chargers only show this error when there is solar power available and thus the device is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. |
- | * For VE.Can solar chargers, go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | + | Solution: check the connection between |
- | * For VE.Direct solar chargers, reset the charger | + | |
- | Note that (solar-)chargers automatically configure themselves | + | __How to reconfigure the charger |
- | === Err 114 - CPU temperature | + | Our Chargers and Solar Chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a GX Device. And that setting is semi-permanent: |
+ | __Background__ | ||
- | === Err 116 - Calibration data lost === | + | ==== Err 116 - Calibration data lost ==== |
- | === Err 119 - Settings data lost === | + | If the error is only present in the history data and the unit operates normally this error can be ignored safely. Explanation: |
+ | ==== Err 119 - Settings data lost ==== | ||
