mppt-error-codes
mppt-error-codes [2016-12-02 13:35] – rvanzundert | mppt-error-codes [2018-05-09 10:27] – [Err 116 - Calibration data lost] rvanzundert | ||
- | ==== Error Codes ==== | + | Detailed error codes can be read with a remote panel, such as the Color Control GX or the MPPT Control. |
- | === Err 2 - Battery voltage too high === | + | ===== Error Codes ===== |
- | + | This error can also occur if the battery voltage is set to a lower voltage than the actual battery voltage. | |
- | === Err 3, Err 4 - Remote temperature sensor failure === | + | ==== Err 3, Err 4 - Remote temperature sensor failure |
Most likely cause: the remote T-sense connector is connected to the BAT+ or BAT- terminal. | Most likely cause: the remote T-sense connector is connected to the BAT+ or BAT- terminal. | ||
This error will auto-reset after proper connection. | This error will auto-reset after proper connection. | ||
- | === Err 5 - Remote temperature sensor failure (connection lost) === | + | ==== Err 5 - Remote temperature sensor failure (connection lost) ==== |
- | === Err 6, Err 7 - Remote battery voltage sense failure === | + | ==== Err 6, Err 7 - Remote battery voltage sense failure |
Most likely cause: the remote V-sense connector is connected in reverse polarity to the BAT+ or BAT- terminals. | Most likely cause: the remote V-sense connector is connected in reverse polarity to the BAT+ or BAT- terminals. | ||
- | === Err 8 - Remote battery voltage sense failure (connection lost) === | + | ==== Err 8 - Remote battery voltage sense failure (connection lost) ==== |
- | === Err 17 - Controller overheated despite reduced output current === | + | ==== Err 17 - Controller overheated despite reduced output current |
This error will auto-reset after charger has cooled down. | This error will auto-reset after charger has cooled down. | ||
Check the ambient temperature and check for obstructions near the heatsink. | Check the ambient temperature and check for obstructions near the heatsink. | ||
- | === Err 18 - Controller over-current === | + | ==== Err 18 - Controller over-current |
Disconnect the charge controller from all power-sources, | Disconnect the charge controller from all power-sources, | ||
- | === Err 20 - Maximum Bulk-time exceeded === | + | ==== Err 20 - Maximum Bulk-time exceeded |
This error can only occur when the maximun bulk-time protection is active. | This error can only occur when the maximun bulk-time protection is active. | ||
Line 44: | Line 47: | ||
Our advice is to not enable it on solar chargers. | Our advice is to not enable it on solar chargers. | ||
- | === Err 21 - Current sensor issue === | + | ==== Err 21 - Current sensor issue ==== |
- | === Err 26 - Terminal overheated === | + | Disconnect all wires, and then reconnect all wires. Also, make sure the minus on the MPPT charge controller (PV minus/ |
- | Power terminals overheated, check wiring and fasten bolts if possible. | + | |
+ | ==== Err 26 - Terminal overheated | ||
+ | Power terminals overheated, check wiring, including the wiring type and type of strands, | ||
- | === Err 33 - PV over-voltage === | + | ==== Err 33 - PV over-voltage |
This error is an indication that the PV-array configuration with regard to open-circuit voltage is critical for this charger. Check configuration, | This error is an indication that the PV-array configuration with regard to open-circuit voltage is critical for this charger. Check configuration, | ||
- | === Err 34 - PV over-current === | + | ==== Err 34 - PV over-current |
The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | ||
- | === Err 38 - Input shutdown | + | ==== Err 38, Err 39 - PV Input shutdown |
- | To protect the battery from over-charging the panel input is shut down. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes reconnect the battery first and next the panels. If the error persists the charge controller is probably faulty. | + | To protect the battery from over-charging the panel input is shorted. |
+ | Error recovery: | ||
+ | * Error 38: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | ||
- | === Information 65 - Communication warning === | + | ==== Information 65 - Communication warning |
- | === Information 66 - Incompatible device === | + | ==== Information 66 - Incompatible device |
Line 73: | Line 91: | ||
- | === Error 67 - No BMS === | + | ==== Err 67 - BMS Connection lost ==== |
- | The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. | + | The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. The charger stopped charging, as a safety precaution. |
Check the connection between the charger and the BMS. | Check the connection between the charger and the BMS. | ||
- | Or, when the charger | + | __How to reset the charger, to de-couple it from the BMS__ |
- | * For VE.Can solar chargers, go into the setup menu, and change setting ‘BMS’ from ‘Y’ | + | When the charger needs to operate in stand-alone mode again, not controlled by a BMS, it needs to be reset: |
- | * For VE.Direct solar chargers, | + | |
- | Note that (solar-)chargers | + | * VE.Can |
+ | * VE.Direct solar chargers, reset the charger | ||
- | === Error 114 - CPU temperature | + | Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. |
- | === Error 116 - Calibration data lost === | + | ==== Err 116 - Calibration data lost ==== |
- | === Error 119 - Settings data lost === | + | ==== Err 119 - Settings data lost ==== |
