mppt-error-codes
mppt-error-codes [2016-10-18 16:14] – Page moved from drafts:mppt-error-codes to mppt-error-codes mvader | mppt-error-codes [2024-02-12 05:48] (current) – [Err 54 - Inverter output voltage] guy_stewart | ||
- | ==== Error Codes ==== | + | Detailed error codes can be read with: |
+ | * Remote panel, such as the Color Control GX or the MPPT Control. | ||
+ | ===== Error Codes ===== | ||
- | === Err 2 - Battery voltage too high (>76,8V) === | ||
- | === Err 17 - Controller overheated despite reduced output current === | + | This error can also occur if the battery voltage (12, 24 48V) is set to a lower voltage than the connected battery. |
+ | ==== Err 3, Err 4 - Remote temperature sensor failure ==== | ||
+ | Check if the T-sense connector is properly connected to a remote temperature sensor. | ||
+ | Most likely cause: the remote T-sense connector is connected to the BAT+ or BAT- terminal. | ||
+ | This error will auto-reset after proper connection. | ||
+ | ==== Err 5 - Remote temperature sensor failure (connection lost) ==== | ||
+ | ==== Err 6, Err 7 - Remote battery voltage sense failure ==== | ||
+ | Check if the V-sense connector is properly connected to the battery terminals. | ||
+ | Most likely cause: the remote V-sense connector is connected in reverse polarity to the BAT+ or BAT- terminals. | ||
+ | ==== Err 8 - Remote battery voltage sense failure (connection lost) ==== | ||
+ | ==== Err 17 - Controller overheated despite reduced output current | ||
This error will auto-reset after charger has cooled down. | This error will auto-reset after charger has cooled down. | ||
Check the ambient temperature and check for obstructions near the heatsink. | Check the ambient temperature and check for obstructions near the heatsink. | ||
- | === Err 18 - Controller over-current === | + | ==== Err 18 - Controller over-current |
- | Disconnect | + | |
- | If the error persists | + | Possible causes for an over-current on the battery terminals: |
+ | Possible solutions | ||
+ | ==== Err 20 - Maximum Bulk-time exceeded ==== | ||
+ | === Solar Chargers === | ||
+ | If you do see this error, then update to the latest firmware. | ||
+ | If you then still have the error, perform a reset to factory defaults of the configuration, | ||
+ | === AC Chargers === | ||
+ | This protection | ||
- | === Err 20 - Maximum Bulk-time exceeded === | ||
This error is generated when the battery-absorption-voltage is not reached after 10 hours of charging. | This error is generated when the battery-absorption-voltage is not reached after 10 hours of charging. | ||
- | This protection | + | The feature of this safety |
- | * Solar Chargers with VE.Direct connection: disabled on all solar chargers, our advice | + | ==== Err 21 - Current sensor issue ==== |
- | * Solar Chargers with VE.Can connection: same as above. | + | |
- | * Skylla-i: default enabled (dipswitch). Only disable it when using this charger on a relatively large battery bank, where charging | + | The current measurement is out of range. |
- | * Skylla IP44: default disabled (settable in the LCD menu). | + | |
+ | Disconnect all wires, and then reconnect all wires, to make restart | ||
- | === Err 21 - Current sensor issue === | ||
- | The charge controller is probably faulty. | ||
- | === Err 26 - Terminal overheated === | + | If the error remains, please contact your dealer, there might be a hardware defect. |
- | Power terminals overheated, check wiring and fasten bolts if possible. | + | |
+ | This error indicates that the fan is powered on but the circuit does not measure any current draw by the fan. Most likely its either broken or obstructed. | ||
+ | ==== Err 26 - Terminal overheated | ||
+ | Power terminals overheated, check wiring, including the wiring type and type of strands, | ||
- | === Err 33 - PV over-voltage === | + | ==== Err 27 - Charger short circuit ==== |
+ | Possible causes: | ||
+ | ==== Err 33 - PV over-voltage | ||
This error is an indication that the PV-array configuration with regard to open-circuit voltage is critical for this charger. Check configuration, | This error is an indication that the PV-array configuration with regard to open-circuit voltage is critical for this charger. Check configuration, | ||
- | === Err 34 - PV over-current === | + | ==== Err 34 - PV over-current |
- | === Err 38 - Input shutdown due to battery | + | ==== Err 35 - PV over-power ==== |
- | To protect the battery from over-charging the panel input is shut down. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes reconnect the battery first and next the panels. If the error persists the charge controller is probably faulty. | + | |
- | === Information 65 - Communication warning === | + | Applies to the MPPT RS, Inverter RS and Multi RS products. |
+ | Error recovery: | ||
+ | ==== Information 65 - Communication warning | ||
- | === Information 66 - Incompatible device === | + | ==== Information 66 - Incompatible device |
- | === Error 67 - No BMS === | + | ==== Err 67 - BMS Connection lost ==== |
- | Connection to the BMS lost, check the connection (Cabling / Bluetooth link). When the charger needs to operate in stand-alone mode again, change to setup menu setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | + | |
+ | This error shows when the charger is configured to be controlled by a BMS, but does not receive any BMS control messages. In that situation, the charger stops charging by reducing its output voltage to the battery base voltage (12V/ | ||
- | 2 mogelijke oorzaken: | + | Solar Chargers only show this error when there is solar power available and thus the device is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. |
- | - de bms is er geweest en daarna ' | + | |
- | - men heeft per abuis de optie bms present op ' | + | |
- | === Error 114 - CPU temperature | + | Solution: check the connection between the charger and the BMS. |
+ | __How to reconfigure the charger to standalone mode__ | ||
+ | Our Chargers and Solar Chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a GX Device. And that setting is semi-permanent: | ||
+ | __Background__ | ||
- | === Error 116 - Calibration data lost === | + | ==== Err 116 - Calibration data lost ==== |
- | The unit is faulty, contact Victron. | + | If the unit does not work and error 116 pops up as the active error the unit is faulty, contact |
+ | ==== Err 119 - Settings data lost ==== | ||
+ | The charger cannot read its configuration, | ||
+ | This error will not auto-reset. To get it working again: | ||
+ | - First, restore it to factory defaults. (top right in Victron Connect, click on the three dots) | ||
+ | - Disconnect the charge controller from all power-sources | ||
+ | - wait 3 minutes, and power up again. | ||
+ | - Reconfigure the charger. | ||
- | === Error 119 - Settings data lost === | + | ==== Err 203, Err 205, Err 212, Err 215 - Internal supply voltage error ==== |
- | This error will not auto-reset. | + | The unit performs internal diagnostics when activating its internal voltage supplies. |
- | Restore defaults in the setup menu (setup item 62). | + | |
- | Disconnect the charge controller from all power-sources, | + | |
