mppt-error-codes
mppt-error-codes [2016-10-18 16:14] – Page moved from drafts:mppt-error-codes to mppt-error-codes mvader | mppt-error-codes [2019-01-22 10:16] – external edit 127.0.0.1 | ||
- | ==== Error Codes ==== | + | Detailed error codes can be read with a remote panel, such as the Color Control GX or the MPPT Control. |
- | === Err 2 - Battery voltage too high (> | + | ===== Error Codes ===== |
- | === Err 17 - Controller overheated despite reduced output current === | + | This error can also occur if the battery voltage is set to a lower voltage than the actual battery voltage. |
+ | ==== Err 3, Err 4 - Remote temperature sensor failure ==== | ||
+ | Check if the T-sense connector is properly connected to a remote temperature sensor. | ||
+ | Most likely cause: the remote T-sense connector is connected to the BAT+ or BAT- terminal. | ||
+ | This error will auto-reset after proper connection. | ||
+ | ==== Err 5 - Remote temperature sensor failure (connection lost) ==== | ||
+ | ==== Err 6, Err 7 - Remote battery voltage sense failure ==== | ||
+ | Check if the V-sense connector is properly connected to the battery terminals. | ||
+ | Most likely cause: the remote V-sense connector is connected in reverse polarity to the BAT+ or BAT- terminals. | ||
+ | ==== Err 8 - Remote battery voltage sense failure (connection lost) ==== | ||
+ | ==== Err 17 - Controller overheated despite reduced output current | ||
This error will auto-reset after charger has cooled down. | This error will auto-reset after charger has cooled down. | ||
Check the ambient temperature and check for obstructions near the heatsink. | Check the ambient temperature and check for obstructions near the heatsink. | ||
- | === Err 18 - Controller over-current === | + | ==== Err 18 - Controller over-current |
- | Disconnect | + | If the error does not auto-reset disconnect |
- | If the error persists the charge controller is probably faulty. | + | A cause for this error can be switching on a very large load on the battery side. |
- | === Err 20 - Maximum Bulk-time exceeded === | + | ==== Err 20 - Maximum Bulk-time exceeded |
This error can only occur when the maximun bulk-time protection is active. | This error can only occur when the maximun bulk-time protection is active. | ||
This error is generated when the battery-absorption-voltage is not reached after 10 hours of charging. | This error is generated when the battery-absorption-voltage is not reached after 10 hours of charging. | ||
- | This protection is default: | + | This protection is default |
- | * Solar Chargers | + | |
- | * Solar Chargers with VE.Can connection: same as above. | + | It is default enabled |
- | * Skylla-i: default enabled (dipswitch). Only disable it when using this charger on a relatively large battery bank, where charging the bank will take more than 10 hourrs. | + | |
- | * Skylla IP44: default disabled (settable in the LCD menu). | + | Our advice is to not enable it on solar chargers. |
+ | ==== Err 21 - Current sensor issue ==== | ||
- | === Err 21 - Current sensor issue === | ||
- | The charge controller is probably faulty. | ||
- | === Err 26 - Terminal overheated === | + | Disconnect all wires, and then reconnect all wires. Also, make sure the minus on the MPPT charge controller (PV minus/ |
- | Power terminals overheated, check wiring and fasten bolts if possible. | + | |
+ | ==== Err 26 - Terminal overheated | ||
+ | Power terminals overheated, check wiring, including the wiring type and type of strands, | ||
- | === Err 33 - PV over-voltage === | + | ==== Err 28 - Power stage issue ==== |
+ | ==== Err 33 - PV over-voltage | ||
This error is an indication that the PV-array configuration with regard to open-circuit voltage is critical for this charger. Check configuration, | This error is an indication that the PV-array configuration with regard to open-circuit voltage is critical for this charger. Check configuration, | ||
- | === Err 34 - PV over-current === | + | ==== Err 34 - PV over-current |
The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | ||
- | === Err 38 - Input shutdown | + | ==== Err 38, Err 39 - PV Input shutdown |
- | To protect the battery from over-charging the panel input is shut down. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes reconnect the battery first and next the panels. If the error persists the charge controller is probably faulty. | + | To protect the battery from over-charging the panel input is shorted. |
- | === Information 65 - Communication warning === | + | Possible reasons for this error to occur: |
+ | Error recovery: | ||
+ | * Error 38: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | ||
+ | ==== Information 65 - Communication warning | ||
- | === Information 66 - Incompatible device === | + | ==== Information 66 - Incompatible device |
Line 56: | Line 97: | ||
- | === Error 67 - No BMS === | + | ==== Err 67 - BMS Connection lost ==== |
- | Connection | + | The charger is configured |
+ | Check the connection between the charger and the BMS. | ||
- | 2 mogelijke oorzaken: | + | __How to reset the charger, to de-couple it from the BMS__ |
- | - de bms is er geweest en daarna ' | + | |
- | - men heeft per abuis de optie bms present op ' | + | |
- | === Error 114 - CPU temperature | + | When the charger needs to operate in stand-alone mode again, not controlled by a BMS, it needs to be reset: |
+ | * VE.Can solar chargers, go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | ||
+ | * VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, | ||
+ | Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. | ||
- | === Error 116 - Calibration data lost === | + | ==== Err 116 - Calibration data lost ==== |
+ | ==== Err 119 - Settings data lost ==== | ||
+ | The charger cannot read its configuration, | ||
+ | This error will not auto-reset. To get it working again: | ||
+ | - First, restore it to factory defaults. | ||
+ | - Disconnect the charge controller from all power-sources | ||
+ | - wait 3 minutes, and power up again. | ||
+ | - Reconfigure the charger. | ||
- | === Error 119 - Settings data lost === | ||
- | Restore defaults in the setup menu (setup item 62). | ||
- | Disconnect the charge controller from all power-sources, | ||
