mppt-error-codes
drafts:mppt-error-codes [2016-10-17 16:06] – mvader | mppt-error-codes [2018-05-08 15:53] – [Err 38, Err 39 - Input shutdown due to battery over-voltage] mvader | ||
- | (draft) | ||
- | ==== Error Codes ==== | + | Solar Chargers indicate an error with their LEDs. See the [[https:// |
- | === Information 66 - Incompatible device === | + | Detailed error codes can be read with a remote panel, such as the Color Control GX or the MPPT Control. |
+ | ===== Error Codes ===== | ||
+ | This error will auto-reset after the battery voltage has dropped. | ||
+ | This error can be due to other charging equipment connected to the battery or a fault in the charge controller. | ||
+ | This error can also occur if the battery voltage is set to a lower voltage than the actual battery voltage. | ||
+ | ==== Err 3, Err 4 - Remote temperature sensor failure ==== | ||
+ | Check if the T-sense connector is properly connected to a remote temperature sensor. | ||
+ | Most likely cause: the remote T-sense connector is connected to the BAT+ or BAT- terminal. | ||
+ | This error will auto-reset after proper connection. | ||
+ | ==== Err 5 - Remote temperature sensor failure (connection lost) ==== | ||
+ | ==== Err 6, Err 7 - Remote battery voltage sense failure ==== | ||
+ | Check if the V-sense connector is properly connected to the battery terminals. | ||
+ | Most likely cause: the remote V-sense connector is connected in reverse polarity to the BAT+ or BAT- terminals. | ||
+ | ==== Err 8 - Remote battery voltage sense failure (connection lost) ==== | ||
+ | ==== Err 17 - Controller overheated despite reduced output current ==== | ||
+ | This error will auto-reset after charger has cooled down. | ||
+ | Check the ambient temperature and check for obstructions near the heatsink. | ||
+ | ==== Err 18 - Controller over-current ==== | ||
+ | Disconnect the charge controller from all power-sources, | ||
+ | ==== Err 20 - Maximum Bulk-time exceeded ==== | ||
+ | This error can only occur when the maximun bulk-time protection is active. | ||
+ | This protection is default disabled in all Solar Chargers. | ||
+ | It is default enabled on the Skylla-i and the Skylla IP44. | ||
+ | Our advice is to not enable it on solar chargers. | ||
+ | ==== Err 21 - Current sensor issue ==== | ||
+ | Disconnect all wires, and then reconnect all wires. Also, make sure the minus on the MPPT charge controller (PV minus/ | ||
+ | ==== Err 26 - Terminal overheated ==== | ||
+ | Power terminals overheated, check wiring, including the wiring type and type of strands, and/or fasten bolts if possible. | ||
+ | ==== Err 33 - PV over-voltage ==== | ||
+ | This error will auto-reset after PV-voltage has dropped to safe limit. | ||
+ | This error is an indication that the PV-array configuration with regard to open-circuit voltage is critical for this charger. Check configuration, | ||
+ | ==== Err 34 - PV over-current ==== | ||
+ | The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | ||
+ | Disconnect the charger from all power-sources, | ||
+ | ==== Err 38, Err 39 - PV Input shutdown ==== | ||
+ | To protect the battery from over-charging the panel input is shorted. | ||
+ | Error recovery: | ||
+ | * Error 38: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | ||
+ | ==== Information 65 - Communication warning ==== | ||
+ | Communication with one of the paralleled controllers was lost. To clear the warning, switch the controller off and back on | ||
+ | ==== Information 66 - Incompatible device | ||
Line 10: | Line 91: | ||
- | === Error 67 - No BMS === | + | ==== Err 67 - BMS Connection lost ==== |
- | Connection | + | The charger is configured |
+ | Check the connection between the charger and the BMS. | ||
- | 2 mogelijke oorzaken: | + | __How to reset the charger, to de-couple it from the BMS__ |
- | - de bms is er geweest en daarna ' | + | |
- | - men heeft per abuis de optie bms present op ' | + | |
- | === Error 114 - CPU temperature | + | When the charger needs to operate in stand-alone mode again, not controlled by a BMS, it needs to be reset: |
+ | * VE.Can solar chargers, go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | ||
+ | * VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, | ||
+ | Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. | ||
- | === Error 116 - Calibration data lost === | + | ==== Err 116 - Calibration data lost ==== |
- | The unit is faulty, contact | + | The unit is faulty, contact |
- | === Error 119 - Settings data lost === | + | ==== Err 119 - Settings data lost ==== |
- | This error will not auto-reset. | + | The charger cannot read its configuration, |
- | Restore | + | |
- | Disconnect the charge controller from all power-sources, wait 3 minutes, and power up again. | + | This error will not auto-reset. |
+ | - First, restore it to factory | ||
+ | - wait 3 minutes, and power up again. | ||
+ | - Reconfigure the charger. | ||
~~DISQUS~~ | ~~DISQUS~~ |
