mppt-error-codes
mppt-error-codes [2019-05-20 10:55] – [Err 116 - Calibration data lost] rvanzundert | mppt-error-codes [2023-07-19 08:54] – [Err 70 - Network misconfigured] rvanzundert | ||
+ | * Remote | ||
Line 26: | Line 40: | ||
Line 32: | Line 58: | ||
- | A cause for this error can be switching on a very large load on the battery side. | + | |
+ | Possible solutions | ||
+ | === AC Chargers === | ||
==== Err 28 - Power stage issue ==== | ==== Err 28 - Power stage issue ==== | ||
Line 65: | Line 128: | ||
Disconnect all wires, and then reconnect all wires. If the error persists the charge controller is probably faulty. | Disconnect all wires, and then reconnect all wires. If the error persists the charge controller is probably faulty. | ||
+ | Possible causes: | ||
Line 70: | Line 143: | ||
- | * Error 39: The charger will automatically resume operation once the battery voltage drops below the float level for 1 minute. | + | * Error 39: The charger will automatically resume operation once the battery voltage drops below its maximum voltage setting (normally Equalisation or Absorption voltages). It can also takes a minute |
+ | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | ||
Line 94: | Line 236: | ||
- | The charger detects multiple conflicting network sources trying to take control of the charger. | + | To clear the error on the SmartSolar VE.Direct MPPTs update the FW version to v1.48 or higher. |
- | Applies to SmartSolar MPPTs and SmartSolar MPPTs VE.Can. | + | To clear the error on the SmartSolar/ |
- | The typical reason for the error to show is that the charger is configured to operate in parallel using our [[https:// | + | __Background__ |
- | Resolution: disable | + | Error 68 indicates that the charger detects multiple conflicting network sources, with the same priority, trying |
- | For SmartSolar MPPT VE.Can only, also make sure its not connected to a [[https:// | + | Having a higher priority level means that, if the same information (e.g. Battery voltage sense) is being received from both VE.Can and BLE (using |
- | Once the conflict | + | Now, if the same information |
Line 138: | Line 326: | ||
- | ~~DISQUS~~ | + | |
