hv_battery_compatibility:zyc
hv_battery_compatibility:zyc [2026-06-17 07:54] – guy_stewarthv_battery_compatibility:zyc [2026-06-22 07:35] (current) – [Compatibility status] guy_stewart
Line 16: Line 16:
 **SIMPO Pro S** **SIMPO Pro S**
   * Modules per stack: **16** (the product allows 10 - 16; 15 or fewer sits below the HS19 range)   * Modules per stack: **16** (the product allows 10 - 16; 15 or fewer sits below the HS19 range)
-  * Usable voltage range: **650 - 934 V** (battery floor is 640 V, so a sliver of capacity at the bottom is unusable; likely acceptable as the cutoff is rarely reached, confirm with ZYC)+  * Usable voltage range: **650 - 934 V**
   * Capacity: **82 kWh** per stack   * Capacity: **82 kWh** per stack
Line 32: Line 32:
 Both: 1 - 16 strings DC parallel; CAN / Modbus TCP / Modbus RTU; IP20/IP55. Both: 1 - 16 strings DC parallel; CAN / Modbus TCP / Modbus RTU; IP20/IP55.
-===== Compatibility status =====
-  * Test status: tested and running in field tests
hv_battery_compatibility/zyc.1781682850.txt.gz · Last modified: by guy_stewart
