hv_battery_compatibility:zyc
ZYC SIMPO Pro
Manufacturer links
- Product page: ZYC SIMPO Pro (AU site, full spec tables)
- Global site: zyc.energy
- Datasheet PDF: not publicly linked; see ZYC download page
Use with the HS19 (650 - 1000 V DC)
SIMPO Pro E
- Modules per stack: 11 only (the product allows 4 - 15; 10 or fewer sits below the HS19 range, 12 or more exceeds 1000 V at full charge)
- Usable voltage range: 673 - 958 V
- Capacity: 127 kWh per stack
SIMPO Pro S
- Modules per stack: 16 (the product allows 10 - 16; 15 or fewer sits below the HS19 range)
- Usable voltage range: 650 - 934 V (battery floor is 640 V, so a sliver of capacity at the bottom is unusable; likely acceptable as the cutoff is rarely reached, confirm with ZYC)
- Capacity: 82 kWh per stack
Product specifications
SIMPO Pro E
- Module ~76.8 V / 11.52 kWh
- Max constant current 150 A
SIMPO Pro S
- Module ~51.2 V / 5.12 kWh
- Max constant current 100 A
Both: 1 - 16 strings DC parallel; CAN / Modbus TCP / Modbus RTU; IP20/IP55.
Compatibility status
- Test status: tested and running in field tests
Setup guide
Contact battery manufacturer for setup instructions.
hv_battery_compatibility/zyc.1781682850.txt.gz · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
