hv_battery_compatibility:mg
MG RS Series
Manufacturer links
- Product page: MG Energy Systems RS Series
- Download centre: MG downloads (RS LFP)
- Datasheet: RS 230 datasheet (MGRS480230M)
Use with the HS19 (650 - 1000 V DC)
- Modules per string: 14 - 15
- Usable voltage range: 672 - 876 V
- Capacity: 165 - 177 kWh per string
Product specifications
- Module RS 230: 51.2 V nominal (16S1P LiFePO4), 230 Ah / 11.8 kWh, liquid thermal management
- Up to 32 modules parallel
- 230 A continuous, 345 A max discharge
- Requires external MG Master HV BMS for HV strings
Compatibility status
- Test status: tested and running in field tests
Setup guide
Contact battery manufacturer for setup instructions.
hv_battery_compatibility/mg.1781683730.txt.gz · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
