hv_battery_compatibility:mg
MG RS Series
Manufacturer links
- Product page: MG Energy Systems RS Series
- Download centre: MG downloads (RS LFP)
- Datasheet: RS 230 datasheet (MGRS480230M)
Use with the HS19 (650 - 1000 V DC)
- Modules per string: 14 - 15 (the product allows 1 - 16; 13 or fewer sits below the HS19 range, and 16 modules would reach 934 V max charge, above MG's own 900 V system limit. Verify with MG.)
- Usable voltage range: 672 - 876 V
- Capacity: 165 - 177 kWh per string
derived from datasheet per-module voltages (48 V cutoff, 58.4 V max charge), not yet verified
Full product specifications (unverified, from manufacturer datasheet)
- Module RS 230: 51.2 V nominal (16S1P LiFePO4), 230 Ah / 11.8 kWh, liquid thermal management
- Up to 32 modules parallel
- 230 A continuous, 345 A max discharge
- Requires external MG Master HV BMS for HV strings
Compatibility status
- Test status: tested and running in field tests
- FDCan support: Master HV does not support it; Master HV Mk2 does
Setup guide
Setup instructions to be written.
hv_battery_compatibility/mg.1781268069.txt.gz · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
