hv_battery_compatibility:lbsa
LBSA HV (Rhino IntelliFlex HV)
Manufacturer links
- HV range page: LBSA High Voltage
- Module spec page: HV module 7.7 kWh rack mount
- User manual (web): HV-104-14WFRE user manual
Use with the HS19 (650 - 1000 V DC)
- Modules per rack: 10 - 11 (the product allows 3 - 11; 9 or fewer sits below the HS19 range)
- Usable voltage range: 660 - 927 V
- Capacity: 80 - 88 kWh per rack
Full product specifications (unverified, from manufacturer pages)
- Module: 76.8 V nominal (24S LiFePO4), 104 Ah / 7.98 kWh
- 100 A continuous per rack (200 A for 60 s); up to 60 racks parallel
Compatibility status
- Test status: tested, now offline
Setup guide
Contact battery manufacturer for setup instructions.
hv_battery_compatibility/lbsa.1781683336.txt.gz · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
