hv_battery_compatibility:freedomwon
Freedomwon LiTE Commercial 300/240 HV+
Manufacturer links
- Product page: Freedom Won LiTE Commercial 300/240 HV+
- Spec sheet: LiTE Commercial HV 300/240 spec sheet
Use with the HS19 (650 - 1000 V DC)
- Factory-built cabinet, no module count to choose
- Usable voltage range: 655 - 817 V (the HV+ operating window fits the HS19 range as-is)
- Capacity: 300 kWh (240 kWh @ 80% DoD)
- Note: the older non-plus HV variant (627 - 780 V) sits partly below the HS19 minimum and is not suitable
Full product specifications (unverified, from manufacturer spec sheet)
- Factory-built cabinet, not field-stackable: 300 kWh total (240 kWh @ 80% DoD), 400 Ah
- Nominal 736 V, operating 655 - 817 V
- 400 A continuous/max, 300 kW
- Cells: 200 Ah / 3.2 V prismatic LiFePO4; scaling by paralleling complete cabinets
- Sibling models: 230/184 HV+ and 400/320 HV+
- Older non-plus HV variant: nominal 768 V, operating 627 - 780 V
Compatibility status
- Test status: tested by battery manufacturer, not tested by Victron
- FDCan support: unknown
Setup guide
Setup instructions to be written.
hv_battery_compatibility/freedomwon.1781268013.txt.gz · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
