Action unknown: plugin_bookcreator__addtobook
hv_battery_compatibility:freedomwon
Freedomwon LiTE Commercial 300/240 HV+
Use with the HS19 (650 - 1000 V DC)
  • Factory-built cabinet, no module count to choose
  • Usable voltage range: 655 - 817 V (the HV+ operating window fits the HS19 range as-is)
  • Capacity: 300 kWh (240 kWh @ 80% DoD)
  • Note: the older non-plus HV variant (627 - 780 V) sits partly below the HS19 minimum and is not suitable
Product specifications
  • Factory-built cabinet, not field-stackable: 300 kWh total (240 kWh @ 80% DoD), 400 Ah
  • Nominal 736 V, operating 655 - 817 V
  • 400 A continuous/max, 300 kW
  • Cells: 200 Ah / 3.2 V prismatic LiFePO4; scaling by paralleling complete cabinets
  • Sibling models: 230/184 HV+ and 400/320 HV+
  • Older non-plus HV variant: nominal 768 V, operating 627 - 780 V
Setup guide
Contact battery manufacturer for setup instructions.
hv_battery_compatibility/freedomwon.txt · Last modified: by guy_stewart
