hv_battery_compatibility:dyness
Dyness
Not yet tested. Current models do not support FDCan; new hardware will.
Use with the HS19 (650 - 1000 V DC)
Current models do not fit. The Tower lines top out at 576 V, below the HS19 minimum of 650 V. Awaiting new hardware.
Manufacturer links
- Homepage: Dyness
- HV range: Residential High Voltage ESS
- Tower series: Tower (T7 - T21, 192 - 576 V)
- Newer lines: Tower Pro (7.68 - 23.04 kWh), Tower S3 (7.1 - 255.72 kWh)
Compatibility status
- Test status: TBD
- FDCan support: current models no; new hardware will support it
Setup guide
To be written once a model is tested.
hv_battery_compatibility/dyness.txt · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
