ess:quick-installation-guide
ess:quick-installation-guide [2019-08-15 11:33] – [Step 3 - Select the system hardware] guy_stewart | ess:quick-installation-guide [2019-09-24 02:07] – [Step 5 - Update firmware of all equipment] mleeftink | ||
Line 31: | Line 31: | ||
Both drawings show all AC- and DC-Coupled combinations. | Both drawings show all AC- and DC-Coupled combinations. | ||
- | {{:ess:ess_multiii.png? | + | {{:ess:ess_with_multiplus-ii.png?400|}} |
Line 62: | Line 61: | ||
And one or more of the Energy Meter accessories: | And one or more of the Energy Meter accessories: | ||
- | * Victron ASS030572018 - RS485 to USB interface 1.8m | + | * Victron ASS030572018 - RS485 to USB interface 1.8m: [[https:// |
* Victron Zigbee to USB and RS485 converter: [[https:// | * Victron Zigbee to USB and RS485 converter: [[https:// | ||
- | To measure PV from a PV Inverter | + | To measure PV power coming |
* Victron Current sensor: [[https:// | * Victron Current sensor: [[https:// | ||
* Victron Energy meters: [[https:// | * Victron Energy meters: [[https:// | ||
- | * Details on how to measure PV Inverter | + | * Details on how to measure |
To equip the system with WiFi you will need: | To equip the system with WiFi you will need: | ||
* Victron WiFi module: BPP900100200 | * Victron WiFi module: BPP900100200 | ||
- | * Details on connecting your [[venus-os: | + | * Details on connecting your [[venus-os: |
In case of a smart battery such as BYD, you might need: | In case of a smart battery such as BYD, you might need: | ||
Line 94: | Line 93: | ||
The easiest way is to let the CCGX or Venus GX do an automatic update. This can be selected from its menu, once it is connected to the internet. Alternatively update via a SD card. For instructions how to update see: [[ccgx: | The easiest way is to let the CCGX or Venus GX do an automatic update. This can be selected from its menu, once it is connected to the internet. Alternatively update via a SD card. For instructions how to update see: [[ccgx: | ||
- | === MPPTs Solar Chargers === | + | === Inverter/ |
Use VictronConnect; | Use VictronConnect; | ||
- | === Multi and Quattro Inverter/ | ||
- | {{youtube> | ||
- | For details, see the [[updating_firmware: | ||
Line 151: | Line 145: | ||
- | ===== Step 9 - Make the Venus-device settings ===== | + | ===== Step 9 - Make the GX device settings ===== |
* Go to ESS settings on CCGX, make ESS settings | * Go to ESS settings on CCGX, make ESS settings | ||
Line 159: | Line 153: | ||
* Find Energy meter(s) on CCGX, assign correct role | * Find Energy meter(s) on CCGX, assign correct role | ||
- | For details, see the [[ess: | + | For details, see the [[ess: |
ess/quick-installation-guide.txt · Last modified: 2023-05-23 10:45 by guy_stewart
