ess:design-installation-manual [2020-08-03 23:57] – [4.3 GX device - ESS Settings] simonhackett | ess:design-installation-manual [2020-08-09 21:53] – [6. Controlling depth of discharge] jono | ||
Line 537: | Line 537: | ||
Start the generator and check that the system begins to charge the batteries. | Start the generator and check that the system begins to charge the batteries. | ||
===== 6. Controlling depth of discharge ===== | ===== 6. Controlling depth of discharge ===== | ||
- | //(Note: All absolute voltages mentioned in the example below refer to a 12V system. Voltages should be multiplied by x2 or x4 for a 24V or 48V system, respectively.)// | + | //(Note: All absolute voltages mentioned in the example below refer to a 12V system. Voltages should be multiplied by x2 for a 24V system |
==== 6.1 Overview === | ==== 6.1 Overview === |
