ess:design-installation-manual [2020-07-29 13:42] – guy_stewart | ess:design-installation-manual [2020-08-09 21:53] – [6. Controlling depth of discharge] jono | ||
Line 347: | Line 347: | ||
* Victron 12.8V Lithium batteries, and other lithium batteries that have passive cell balancing | * Victron 12.8V Lithium batteries, and other lithium batteries that have passive cell balancing | ||
- | Because it makes no sense to leave a battery discharged, without reserve power in case of mains failure, we recommend leaving BatteryLife enabled | + | Because it makes no sense to leave a battery discharged, without reserve power in case of mains failure, we recommend leaving BatteryLife enabled |
- | * Lithium with active cell balancing | + | Redflow specifies that BatteryLife should be disabled in [[battery_compatibility: |
=== 4.3.2 Grid meter installed === | === 4.3.2 Grid meter installed === | ||
Line 540: | Line 537: | ||
Start the generator and check that the system begins to charge the batteries. | Start the generator and check that the system begins to charge the batteries. | ||
===== 6. Controlling depth of discharge ===== | ===== 6. Controlling depth of discharge ===== | ||
- | //(Note: All absolute voltages mentioned in the example below refer to a 12V system. Voltages should be multiplied by x2 or x4 for a 24V or 48V system, respectively.)// | + | //(Note: All absolute voltages mentioned in the example below refer to a 12V system. Voltages should be multiplied by x2 for a 24V system |
==== 6.1 Overview === | ==== 6.1 Overview === | ||
Line 693: | Line 690: | ||
(Make sure you install the ESS on L1. If it's installed on another phase the visualisation will be wrong.) | (Make sure you install the ESS on L1. If it's installed on another phase the visualisation will be wrong.) | ||
- | ==== 7.2 Three-phase ESS ==== | + | ==== 7.3 Three-phase ESS ==== |
A three-phase ESS system has at least one Multi installed on each phase. We recommend leaving the phase-compensation setting to its default: enabled. | A three-phase ESS system has at least one Multi installed on each phase. We recommend leaving the phase-compensation setting to its default: enabled. | ||
Line 953: | Line 950: | ||
- Now check MPPT Charge Voltage Setpoint. It is supposed to be above actual battery voltage. | - Now check MPPT Charge Voltage Setpoint. It is supposed to be above actual battery voltage. | ||
- | Note that those last two set points are determined by software; and calculated based on the setpoints sent by the (CANbus connected) lithium battery: you can' | + | Note that those last two set points are determined by software; and calculated based on the setpoints sent by the (CANbus connected) lithium battery: you can't change them manually. Looking at them however does help understanding why certain things are happening; |
~~DISQUS~~ | ~~DISQUS~~ |
