ess:design-installation-manual [2019-12-10 21:50] – boekel | ess:design-installation-manual [2021-01-14 08:35] (current) – marmour | ||
- | * [[https:// | + | |
- | * Marine systems. | + | |
- | === Energy Storage System introduction, | + | |
- | A seperate document that provides further introductory information, | + | |
- | See [[ess: | + | |
- | === Inverter/ | + | |
- | === GX device === | + | |
- | === Battery === | + | |
- | * https:// | + | |
- | https:// | + | |
- | A grid meter is not required where there are no AC renewable-energy source(s) and also no AC load(s) present on the the //input// side of the Multi/ | + | |
- | If there is any AC renewable energy source //or// any AC load between the grid connection point and the input side of the Multi/ | + | |
- | In particular, without a grid meter: | + | |
- | * When renewable energy is being provided on the input side, the grid value will be wrong (too low/ | + | |
- | * The AC Load value shown will be too low (and will show zero where there is a surplus of renewable energy). | + | |
- | Both issues are resolved by installing a grid meter. | + | |
- | [[https:// | + | |
- | ==== 2.1 PV ==== | + | |
- | __Feed-in__ | + | |
- | __No feed-in__ | + | |
- | * on the AC out. | + | |
- | See [[: | + | |
- | ==== 4.2 Multi/ | + | |
- | General notes: | + | |
- | ==== 4.3 GX device - ESS Settings ==== | + | |
- | ** BatteryLife ** | + | |
- | * OPzV, OPzS | + | |
- | * GEL / AGM | + | |
- | Setting this to ' | + | |
- | Set to ' | + | |
- | Please note that when enabling this option, the DVCC charge current limit configured under Settings -> Limit charge current won't be active. The Solar charger will operate at full power for maximum feed-in into the grid. It's advisable to configure a safe limit on the solar chargers when used with a small battery bank. | + | |
- | Notes: | + | |
- | * In Settings-> | + | |
- | Do not use a Fronius Smart Meter for limiting export when part of a Victron ESS System. More details about when a Fronius Smart Meter can, and can not be used is explained [[ac_coupling: | + | |
- | ==== 4.4 GX device - Scheduled Charging ==== | + | |
- | ==== 4.5 GX device - Other settings ==== | + | |
- | The blue ' | + | |
- | __Mains present__ | + | |
- | __Mains outage__ | + | |
- | * Dynamic cut-off | + | |
- | The // | + | |
- | === Details === | + | |
- | The dynamic // | + | |
- | Notes: | + | |
- | ==== 6.5 ESS Battery Status Reason Code Numbers ==== | + | |
- | In addition to the charger states (Bulk/ | + | |
- | The key for these codes is: | + | |
- | * #1: SOC is low | + | |
- | ^ ^ L1^ | + | |
- | ^ Load | + | |
- | * The Multi' | + | |
- | === Policies === | + | |
- | For example // | + | |
- | === Make use of ' | + | |
- | The ESS // | + | |
- | * In __Optimize mode__ whether the load is great or small power will be supplied by the batteries. The Grid meter will be kept at 0W until either the battery is drained or the load exceeds the inverter' | + | |
- | * In __Keep Batteries charged mode__ no power comes from the batteries to power loads unless the grid fails. PV power, when available, will be used to power the loads. There is a known issue when using “Keep batteries charged” mode that can result in less production from the MPPT solar charger when batteries are full. This only occurs when [[https:// | + | |
- | The current options to work around this "Keep Batteries charged" | + | |
- | * Enable [[https:// | + | |
- | * Set the mode to Optimize, and set the minimum SOC to 100%. Note that with this workaround there is still a difference with the “Keep batteries charged” mode: the system will not recharge the battery from the grid after a power outage | + | |
- | * When discharge is not allowed (BMS max discharge current = 0A, or low SOC, etc...) and loads on AC-Out force the Multi/ | + | |
- | * The MPPTs are always in the `ESS` state. This indicates that the MPPT is being controlled by the Multi or Quattro via the GX device. To view the system state, look at the VE.Bus State. | + | |
- | * Others: | + | |
- | === Q9: Why are my loads powered by the grid instead of battery or solar? === | + | |
- | Check list in case loads are being powered from the mains/grid, while expected to be powered from the battery: | + | |
- | __First of all__, check that the system is not preventing discharge because the battery state of charge is below a limit. See the [[# | + | |
- | __Secondly__, | + | |
- | __Thirdly__, | + | |
- | The relay test will be performed once either the battery voltage has been recharged above 14/28/56 volt, or when the battery has been recharged to above 20% SOC. To check if a system is in this state, see the ESS Relay test entry in the Advanced submenu of the Multi/ | + | |
- | __Fourthly__, | + | |
- | __Lastly__, check that the rocker switch on the unit is set to On, rather than to Charger-Only. When set to charger-only, | + | |
- | === Q11: What is auto-recharge? | + | |
- | === Q12: Can I use ESS in a vehicle or a boat? === | + | |
- | The same applies to other solutions where the wiring is not protected against accidental removing, for example a simple cable with end-user removable plug, such as a portable power supply. | + | |
- | ===== Troubleshooting ===== | + | |
- | - Start with checking firmware versions (needs to be latest). And when asking questions; report the exact firmware versions that are used. | + | |
- | - Check battery type/brand. If lead then it might be unsuitable and probably broken because of the heavy cycling. | + | |
- | - If some unknown or unsupported CANbus battery; change the battery to a supported type. | + | |
- | Then; if PV is not used enough to power loads; | + | |
- | - Check for the # reason codes; see CODE KEY in this manual. | + | |
- | - Check wiring: lots of voltage drop between MPPT and multi will prevent the system from effectively powering AC loads from solar power. | + | |
- | - Test with and without SVS enabled. | + | |
- | - Next, check MPPT charge current limit during the time that it is not used enough. MPPT CCL is supposed to be high always; even when battery full. Unless there is a temperature issue. | + | |
- | - Now check MPPT Charge Voltage Setpoint. It is supposed to be above actual battery voltage. | + | |
- | Note that those last two setpoints are determined by software; and calculated based on the setpoints sent by the (CANbus connected) lithium battery: you can't change change them manually. Looking at them however does help understanding why certains things are happening; | + | |
