ess:design-installation-manual [2019-08-15 11:59] – replace venus-device with GX device guy_stewart | ess:design-installation-manual [2019-10-07 10:02] – boekel | ||
Line 146: | Line 146: | ||
For a full or partial grid-parallel installation an Energy Meter can be installed in the main distribution panel between the grid and the installation. | For a full or partial grid-parallel installation an Energy Meter can be installed in the main distribution panel between the grid and the installation. | ||
- | https:// | + | https:// |
A grid meter is only // | A grid meter is only // | ||
Line 836: | Line 836: | ||
=== Q4: Why is the VE.Bus state in // | === Q4: Why is the VE.Bus state in // | ||
- | In ESS, the conditions for the VE.Bus system to be in // | + | In ESS, the conditions for the VE.Bus system to be in // |
* When the CCGX is no longer receiving data from the grid meter. Note that this is only for systems that are configured with an external grid meter. For systems without grid meter, see the Settings -> ESS -> Control without grid-meter setting. | * When the CCGX is no longer receiving data from the grid meter. Note that this is only for systems that are configured with an external grid meter. For systems without grid meter, see the Settings -> ESS -> Control without grid-meter setting. |
