ess:design-installation-manual [2018-11-20 12:38] – [1. ESS Introduction & features] mvader | ess:design-installation-manual [2020-10-19 14:07] – marmour | ||
- | Energy Storage System (ESS) is a specific type of power system that integrates a power grid connection with a Victron Inverter/ | + | |
- | * [[https:// | + | |
- | And on the Venus-device, | + | |
- | * Marine systems. | + | |
- | See [[ess: | + | |
- | === Inverter/ | + | |
- | === Venus-device === | + | |
- | === Battery === | + | |
- | * https:// | + | |
- | https:// | + | |
- | A grid meter is only // | + | |
- | ==== 2.1 PV ==== | + | |
- | __Feed-in__ | + | |
- | __No feed-in__ | + | |
- | * on the AC out. | + | |
- | See [[: | + | |
- | ==== 4.2 Multi/ | + | |
- | General notes: | + | |
- | ==== 4.3 Venus-device - ESS Settings ==== | + | |
- | ** BatteryLife ** | + | |
- | * OPzV, OPzS | + | |
- | * GEL / AGM | + | |
- | Setting this to ' | + | |
- | Set to ' | + | |
- | Notes: | + | |
- | * In Settings-> | + | |
- | ==== 4.4 Venus-device - Scheduled Charging ==== | + | |
- | The Scheduled Charging setting is located in the ESS menu of the Venus-device. It allows you to set up to five scheduled periods, during which the system will take power from the grid to charge the battery. This is typically used to charge the battery during off-peak tariff time windows (TOU). For each schedule, configure a start-time, duration, and optionally set the percentage up to which you want the battery to be charged. | + | |
- | Scheduled charging is available as part of ESS. It is accessible on the Venus-device menus under Settings -> ESS. It is only available when the ESS mode is set to Optimised. Scheduled charging naturally makes no sense when the mode is set to Keep Batteries Charged. | + | |
- | ==== 4.5 Venus-device - Other settings ==== | + | |
- | The blue ' | + | |
- | __Mains present__ | + | |
- | __Mains outage__ | + | |
- | * Dynamic cut-off | + | |
- | The // | + | |
- | === Details === | + | |
- | The dynamic // | + | |
- | Notes: | + | |
- | ^ ^ L1^ | + | |
- | ^ Load | + | |
- | * The Multi' | + | |
- | === Policies === | + | |
- | For example // | + | |
- | === Make use of ' | + | |
- | The ESS // | + | |
- | In __Keep batteries charged mode__ no power comes from the batteries to power loads unless the grid fails. PV power, when available, will always be used to power the loads. | + | |
- | In __Optimize mode__ whether the load is great or small power will be supplied by the batteries. The Grid meter will be kept at 0W until either the battery is drained or the load exceeds the inverter' | + | |
- | * When discharge is not allowed (BMS max discharge current = 0A, or low SOC, etc...) and loads on AC-Out force the Multi/ | + | |
- | * The MPPTs are always in the `ESS` state. This indicates that the MPPT is being controlled by the Multi or Quattro. To view the system state, look at the VE.Bus State. | + | |
- | * Others: | + | |
- | === Q9: Why does my MultiGrid refuse to feed-in? === | + | |
- | A MultiGrid system can enter a state where feed-in (more precisely: converting DC to AC while connected to the grid) is disabled.\\ This happens when, at the moment of connection to the grid, there is not enough DC power to perform the required relay test. (N.B. this relay test is part of the grid code specification - and is mandatory). In order to perform this test the Multigrid must be able to run from battery during a period of time (depending on the selected grid code but usually about 1 minute).\\ If this is not possible, the system enters a // | + | |
- | Therefore there is no need to worry - the system will resume feed-in automatically once the battery has been charged. | + | |
- | === Q11: My Battery is not discharging === | + | |
- | A similar wording for the same question is: my loads are being powered from the mains, rather than the battery. | + | |
- | See the [[# | + | |
- | === Q12: What is auto-recharge? | + | |
