ess:design-installation-manual [2018-06-20 14:00] – [4.1 Update to latest firmware] guystewart | ess:design-installation-manual [2020-10-19 14:07] – marmour | ||
- | An ESS (Energy Storage System) is a grid-tie installation, | + | |
- | * [[https:// | + | |
- | And on the Venus-device, | + | |
- | * Marine systems. | + | |
- | See [[ess: | + | |
- | === Inverter/ | + | |
- | === Venus-device === | + | |
- | === Battery === | + | |
- | * https:// | + | |
- | https:// | + | |
- | A grid meter is only // | + | |
- | ==== 2.1 PV ==== | + | |
- | __Feed-in__ | + | |
- | __No feed-in__ | + | |
- | * on the AC out. | + | |
- | See [[: | + | |
- | - Venus-OS v2.15 or newer. Instructions to upgrade to v2.00 [[ccgx: | + | |
- | ==== 4.2 Multi/ | + | |
- | General notes: | + | |
- | ==== 4.3 Venus-device - ESS Settings ==== | + | |
- | ** BatteryLife ** | + | |
- | * OPzV, OPzS | + | |
- | * GEL / AGM | + | |
- | === 4.3.2 Control without grid meter === | + | |
- | Set to ' | + | |
- | Setting this to ' | + | |
- | Notes: | + | |
- | * In Settings-> | + | |
- | ==== 4.4 Venus-device - Other settings ==== | + | |
- | === 4.4.1 Settings -> System setup -> AC Input types === | + | |
- | === 4.4.2 Settings -> Generator start/stop === | + | |
- | ==== 4.5 MPPT Solar Charger ==== | + | |
- | The blue ' | + | |
- | __Mains present__ | + | |
- | __Mains outage__ | + | |
- | * Dynamic cut-off | + | |
- | The // | + | |
- | === Details === | + | |
- | The dynamic // | + | |
- | Notes: | + | |
- | ^ ^ L1^ | + | |
- | ^ Load | + | |
- | * The Multi' | + | |
- | === Policies === | + | |
- | For example // | + | |
- | === Make use of ' | + | |
- | The ESS // | + | |
- | In __Keep batteries charged mode__ no power comes from the batteries to power loads unless the grid fails. PV power, when available, will always be used to power the loads. | + | |
- | In __Optimize mode__ whether the load is great or small power will be supplied by the batteries. The Grid meter will be kept at 0W until either the battery is drained or the load exceeds the inverter' | + | |
- | With ESS in Optimize mode the system will always remain connected - even when the batteries are full. And although connected, the power draw is not substantial - yet this configuration offers the stability of the grid for nothing. | + | |
- | * When discharge is not allowed (BMS max discharge current = 0A, or low SOC, etc...) and loads on AC-Out force the Multi/ | + | |
- | * The MPPTs are always in the `ESS` state. This indicates that the MPPT is being controlled by the Multi or Quattro. To view the system state, look at the VE.Bus State. | + | |
- | * Others: | + | |
- | === Q9: Why does my MultiGrid refuse to feed-in? === | + | |
- | A MultiGrid system can enter a state where feed-in (more precisely: converting DC to AC while connected to the grid) is disabled.\\ This happens when, at the moment of connection to the grid, there is not enough DC power to perform the required relay test. (N.B. this relay test is part of the grid code specification - and is mandatory). In order to perform this test the Multigrid must be able to run from battery during a period of time (depending on the selected grid code but usually about 1 minute).\\ If this is not possible, the system enters a // | + | |
- | Therefore there is no need to worry - the system will resume feed-in automatically once the battery has been charged. | + | |
- | The recharge is part of sustain. Consider increasing the minimum SOC level. For example increase it with 5%; and then check what happens. | + | |
