drafts:victron_manual_of_style [2020-04-21 09:48] – [List of words that are often written incorrectly] guy_stewart | drafts:victron_manual_of_style [2025-06-27 16:40] (current) – [List of words that are often written incorrectly] jono | ||
Line 38: | Line 38: | ||
* Color Control GX or CCGX | * Color Control GX or CCGX | ||
* Venus GX or VGX | * Venus GX or VGX | ||
- | * GX device - collective name for CCGX, VGX, Cerbo GX and so on. | + | |
* equalisation - UK spelling, not Equalization | * equalisation - UK spelling, not Equalization | ||
* synchronise or synchronisation - UK spelling, not synchronize or synchronization | * synchronise or synchronisation - UK spelling, not synchronize or synchronization | ||
Line 51: | Line 52: | ||
* BMS-Can - The implementation of CAN-bus that is specific to managed batteries in Victron GX devices | * BMS-Can - The implementation of CAN-bus that is specific to managed batteries in Victron GX devices | ||
* MultiPlus-II | * MultiPlus-II | ||
+ | * Node-RED | ||
+ | * Modbus-TCP | ||
+ | * Signal K (yes with that confusing space) | ||
+ | * run time - as in generator run time. not runtime or run-time | ||
+ | * Passthrough | ||
+ | * Victron Recommended Software Integrator Program | ||
+ | * VRM Online Portal, or VRM Portal - also fine to just be VRM, but when using Online and/or Portal capitalise them | ||
+ | * VRM Portal ID - unique GX device hexadecimal code used to register on VRM, not site id. | ||
+ | * BMS plural is BMSs. Incorrect: BMS's, BMSes, | ||
+ | * Switch pane - the name of the switch area that is an option on a GX device menu. | ||
Line 70: | Line 82: | ||
==== Style ==== | ==== Style ==== | ||
- | If in doubt //The Economist// has one of the best style guides I know of: http://www.economist.com/styleguide/introduction | + | If in doubt //The Economist// has one of the best style guides I know of: https://profilebooks.com/work/the-economist-style-guide/ |
drafts/victron_manual_of_style.1587455322.txt.gz · Last modified: by guy_stewart
