drafts:victron_manual_of_style [2018-06-06 14:24] – guystewart | drafts:victron_manual_of_style [2024-03-07 09:44] (current) – [List of words that are often written incorrectly] guy_stewart | ||
The Victron Manual of Style (MoS), is a set of evolving and aspirational standards for the writing and design of documents. Victron' | The Victron Manual of Style (MoS), is a set of evolving and aspirational standards for the writing and design of documents. Victron' | ||
- | ===== A ===== | ||
==== Acronyms ==== | ==== Acronyms ==== | ||
Start a document with the full name of the acronym and then the acronym in brackets. Use just the acronym after that. Example: Battery Management System (BMS) and thereafter use just BMS. | Start a document with the full name of the acronym and then the acronym in brackets. Use just the acronym after that. Example: Battery Management System (BMS) and thereafter use just BMS. | ||
- | ===== L ===== | ||
==== Language ==== | ==== Language ==== | ||
- | Use US English, as opposed to UK English. | + | Use British |
- | ===== N ===== | + | |
==== Numbers ==== | ==== Numbers ==== | ||
Line 20: | Line 16: | ||
Ref: http:// | Ref: http:// | ||
- | ===== P ===== | ||
==== Punctuation ==== | ==== Punctuation ==== | ||
Line 30: | Line 25: | ||
* Capitalisation, | * Capitalisation, | ||
* Punctuation, | * Punctuation, | ||
- | * Omission or inclusion of spaces. | + | * Omission or inclusion of spaces |
- | VE.Direct | + | ===== List of words that are often written incorrectly ===== |
- | VE.Bus | + | * VE.Direct |
+ | * VE.Bus | ||
+ | * VE.Can | ||
+ | * VE.Smart | ||
+ | * CAN-bus | ||
+ | * VictronConnect | ||
+ | * VEConfigure | ||
+ | * Color Control GX or CCGX | ||
+ | * Venus GX or VGX | ||
+ | * GX device - collective name for CCGX, VGX, Cerbo GX and so on. | ||
+ | * equalisation - UK spelling, not Equalization | ||
+ | * Grid-connected - similar to off-grid. | ||
+ | * MultiPlus-II | ||
+ | * Node-RED | ||
+ | * Modbus-TCP | ||
+ | * Signal K (yes with that confusing space) | ||
+ | * run time - as in generator run time. not runtime or run-time | ||
- | VE.Can | ||
- | CAN-bus | + | ==== GX Product Classifications ==== |
- | VictronConnect | + | * GX product range - all GX devices (eg CCGX), and their accessories (eg GX GSM). |
- | VEConfigure | + | * GX device - any member of that family eg Venus GX and Octo GX, but not inclusive of the accessories. |
- | CCGX | + | * GX Card - a circuit board featuring all the GX features that is used in the integrated products, eg EasySolar-II GX and MultiPlus-II GX. |
- | Color Control | + | Products that have the GX suffix are a GX device, or contain a GX device. |
+ | Products that have a GX prefix are accessories for a GX device. | ||
+ | Generally, public/ | ||
+ | Specific internal/ | ||
+ | ==== Style ==== | ||
+ | If in doubt //The Economist// has one of the best style guides I know of: https:// | ||
+ | ==== Type Faces Used ==== | ||
+ | * Myriad Pro-Bold | ||
+ | * Myriad Pro | ||
+ | * Helvetica Neue regular, bold and condensed black | ||
+ | * Arial regular and bold | ||
+ | ==== Units ==== | ||
+ | Use the International System of Units. for more info see [[https:// | ||
+ | ==== Victron Energy departments - names and definitions ==== | ||
+ | **Service Department** - Sometimes referred to as " | ||
+ | **Repair Centre** (previously called Service Partner) - These are external companies (customers) who perform product repairs on behalf of the Victron Energy Service Department. | ||
- | VENUS GX | ||
- | CCGX/VENUS GX - Referred to collectively as 'VENUS device' | ||
- | ===== S ===== | ||
- | ==== Spelling ==== | ||
- | There are several areas in which British and American spelling are different. Use the American spelling. | ||
- | Ref: | ||
- | ==== Style ==== | ||
- | If in doubt //The Economist// has one of the best style guides I know of: http:// | ||
drafts/victron_manual_of_style.1528287889.txt.gz · Last modified: 2018-06-06 14:24 by guystewart
