| drafts:victron_manual_of_style [2025-06-26 13:16] – [List of words that are often written incorrectly] jono | drafts:victron_manual_of_style [2026-07-29 07:41] (current) – [Units] jono | ||
| Line 34: | Line 34: | ||
| * VE.Smart | * VE.Smart | ||
| * CAN-bus | * CAN-bus | ||
| - | * VictronConnect | + | * VictronConnect |
| * VEConfigure | * VEConfigure | ||
| * Color Control GX or CCGX | * Color Control GX or CCGX | ||
| Line 62: | Line 62: | ||
| * VRM Portal ID - unique GX device hexadecimal code used to register on VRM, not site id. | * VRM Portal ID - unique GX device hexadecimal code used to register on VRM, not site id. | ||
| * BMS plural is BMSs. Incorrect: BMS's, BMSes, | * BMS plural is BMSs. Incorrect: BMS's, BMSes, | ||
| + | * Switch pane - the name of the switch area that is an option on a GX device menu. | ||
| + | * AC-IN and AC-OUT | ||
| + | * NMEA 2000 | ||
| Line 94: | Line 97: | ||
| Use the International System of Units. for more info see [[https:// | Use the International System of Units. for more info see [[https:// | ||
| - | There should not be a space between the value and the unit. Example 12V. | + | There should not be a space between the value and the unit. Example 12V & 3000VA. |
| - | When using a symbol as prefix, like m for milli, K for kilo or M for mega, these are written either capitalized or are lowercase. The symbols for mega and above are capitals, while kilo and below are lowercase. Example 12MW, 5kVA and 10mA. | + | When using a symbol as prefix, like m for milli, K for kilo or M for mega, these are written either capitalized or are lowercase. The symbols for mega and above are capitals, while kilo and below are lowercase. Example 12MW, 5kVA, 100Ah and 10mA. |
| + | ==== Currency ==== | ||
| + | No space between the currency symbol and the figure. Use a comma as the thousands separator and a full stop before the pence or cents. For example: £12,500 / £12,500.89 / €12.57 / €120, | ||
| + | Include a three letter indication when dealing with multiple currencies when showing the Dollar sign to avoid confusion. Example $5000 USD, $864.50 AUD. | ||
| ==== Victron Energy departments - names and definitions ==== | ==== Victron Energy departments - names and definitions ==== | ||
drafts/victron_manual_of_style.1750943814.txt.gz · Last modified: by jono
