| drafts:victron_manual_of_style [2025-06-21 01:58] – [List of words that are often written incorrectly] guy_stewart | drafts:victron_manual_of_style [2026-07-29 07:41] (current) – [Units] jono | ||
| Line 34: | Line 34: | ||
| * VE.Smart | * VE.Smart | ||
| * CAN-bus | * CAN-bus | ||
| - | * VictronConnect | + | * VictronConnect |
| * VEConfigure | * VEConfigure | ||
| * Color Control GX or CCGX | * Color Control GX or CCGX | ||
| * Venus GX or VGX | * Venus GX or VGX | ||
| + | * SolidSwitch | ||
| * GX device - collective name for CCGX, VGX, Cerbo GX, Ekrano GX and so on. | * GX device - collective name for CCGX, VGX, Cerbo GX, Ekrano GX and so on. | ||
| * equalisation - UK spelling, not Equalization | * equalisation - UK spelling, not Equalization | ||
| Line 61: | Line 62: | ||
| * VRM Portal ID - unique GX device hexadecimal code used to register on VRM, not site id. | * VRM Portal ID - unique GX device hexadecimal code used to register on VRM, not site id. | ||
| * BMS plural is BMSs. Incorrect: BMS's, BMSes, | * BMS plural is BMSs. Incorrect: BMS's, BMSes, | ||
| + | * Switch pane - the name of the switch area that is an option on a GX device menu. | ||
| + | * AC-IN and AC-OUT | ||
| + | * NMEA 2000 | ||
| Line 80: | Line 84: | ||
| ==== Style ==== | ==== Style ==== | ||
| - | If in doubt //The Economist// has one of the best style guides I know of: https://shop.economist.com/collections/ | + | If in doubt //The Economist// has one of the best style guides I know of: https://profilebooks.com/work/ |
| Line 93: | Line 97: | ||
| Use the International System of Units. for more info see [[https:// | Use the International System of Units. for more info see [[https:// | ||
| - | There should not be a space between the value and the unit. Example 12V. | + | There should not be a space between the value and the unit. Example 12V & 3000VA. |
| - | When using a symbol as prefix, like m for milli, K for kilo or M for mega, these are written either capitalized or are lowercase. The symbols for mega and above are capitals, while kilo and below are lowercase. Example 12MW, 5kVA and 10mA. | + | When using a symbol as prefix, like m for milli, K for kilo or M for mega, these are written either capitalized or are lowercase. The symbols for mega and above are capitals, while kilo and below are lowercase. Example 12MW, 5kVA, 100Ah and 10mA. |
| + | ==== Currency ==== | ||
| + | No space between the currency symbol and the figure. Use a comma as the thousands separator and a full stop before the pence or cents. For example: £12,500 / £12,500.89 / €12.57 / €120, | ||
| + | Include a three letter indication when dealing with multiple currencies when showing the Dollar sign to avoid confusion. Example $5000 USD, $864.50 AUD. | ||
| ==== Victron Energy departments - names and definitions ==== | ==== Victron Energy departments - names and definitions ==== | ||
drafts/victron_manual_of_style.1750471093.txt.gz · Last modified: by guy_stewart
