drafts:victron_manual_of_style [2020-03-17 15:22] – [List of words that are often written incorrectly] guy_stewart | drafts:victron_manual_of_style [2024-03-07 09:44] (current) – [List of words that are often written incorrectly] guy_stewart | ||
Line 47: | Line 47: | ||
* PIN code – not pincode or pin code | * PIN code – not pincode or pin code | ||
* NMEA 2000, or N2K - note the spacing | * NMEA 2000, or N2K - note the spacing | ||
+ | * Grid-connected - similar to off-grid. | ||
+ | * MultiPlus-II | ||
+ | * Node-RED | ||
+ | * Modbus-TCP | ||
+ | * Signal K (yes with that confusing space) | ||
+ | * run time - as in generator run time. not runtime or run-time | ||
Line 66: | Line 75: | ||
==== Style ==== | ==== Style ==== | ||
- | If in doubt //The Economist// has one of the best style guides I know of: http://www.economist.com/ | + | If in doubt //The Economist// has one of the best style guides I know of: https://shop.economist.com/ |
