drafts:victron_manual_of_style [2019-11-13 16:39] – [Victron Energy departments - names and definitions] mleeftink | drafts:victron_manual_of_style [2022-09-13 11:02] – [List of words that are often written incorrectly] mvader | ||
Line 27: | Line 27: | ||
* VE.Bus | * VE.Bus | ||
* VE.Can | * VE.Can | ||
+ | * VE.Smart | ||
* CAN-bus | * CAN-bus | ||
- | * CCGX/VGX - Referred | + | * GX device - collective name for CCGX, VGX, Cerbo GX and so on. |
- | * Equalisation | + | * equalisation |
+ | * Grid-connected - similar | ||
+ | * MultiPlus-II | ||
+ | * Node-RED | ||
+ | * Modbus-TCP | ||
+ | * Signal K (yes with that confusing space) | ||
Line 56: | Line 74: | ||
==== Style ==== | ==== Style ==== | ||
- | If in doubt //The Economist// has one of the best style guides I know of: http://www.economist.com/ | + | If in doubt //The Economist// has one of the best style guides I know of: https://shop.economist.com/ |
==== Type Faces Used ==== | ==== Type Faces Used ==== | ||
- | * MyriadPro-Bold | + | * Myriad Pro-Bold |
- | * MyriadPro-It | + | * Myriad Pro |
* Helvetica Neue regular, bold and condensed black | * Helvetica Neue regular, bold and condensed black | ||
* Arial regular and bold | * Arial regular and bold | ||
- | There should be a space between the value and the unit. Example | + | There should |
- | When using a symbol as prefix, like m for milli, K for kilo or M for mega, these are written either capitalized or are lowercase. The symbols for mega and above are capitals, while kilo and below are lowercase. Example | + | When using a symbol as prefix, like m for milli, K for kilo or M for mega, these are written either capitalized or are lowercase. The symbols for mega and above are capitals, while kilo and below are lowercase. Example |
==== Victron Energy departments - names and definitions ==== | ==== Victron Energy departments - names and definitions ==== |
