drafts:victron_manual_of_style [2019-09-10 05:53] – [Units] mleeftink | drafts:victron_manual_of_style [2020-03-30 01:39] – [List of words that are often written incorrectly] guy_stewart | ||
Line 27: | Line 27: | ||
* VE.Bus | * VE.Bus | ||
* VE.Can | * VE.Can | ||
+ | * VE.Smart | ||
* CAN-bus | * CAN-bus | ||
- | * CCGX/VGX - Referred to collectively as a GX device. | + | * GX device - collective name for CCGX, VGX, Cerbo GX and so on. |
- | * Equalisation | + | * equalisation - UK spelling, not Equalization |
+ | * Grid-connected - similar to off-grid. | ||
Line 61: | Line 73: | ||
==== Type Faces Used ==== | ==== Type Faces Used ==== | ||
- | * MyriadPro-Bold | + | * Myriad Pro-Bold |
- | * MyriadPro-It | + | * Myriad Pro |
* Helvetica Neue regular, bold and condensed black | * Helvetica Neue regular, bold and condensed black | ||
* Arial regular and bold | * Arial regular and bold | ||
+ | ==== Victron Energy departments - names and definitions ==== | ||
+ | **Service Department** - Sometimes referred to as " | ||
- | There should be a space between | + | **Repair Centre** (previously called Service Partner) - These are external companies (customers) who perform product repairs on behalf of the Victron Energy Service Department. |
- | When using a symbol as prefix, like m for milli, K for kilo or M for mega, these are written either capitalized or are lowercase. The symbols for mega and above are capitals, while kilo and below are lowercase. Example 12 MW, 5 kVA and 10 mA. | ||
