drafts:victron_manual_of_style [2019-08-12 15:19] – [GX Product Classifications] guy_stewart | drafts:victron_manual_of_style [2024-03-07 09:44] (current) – [List of words that are often written incorrectly] guy_stewart | ||
Line 27: | Line 27: | ||
* VE.Bus | * VE.Bus | ||
* VE.Can | * VE.Can | ||
+ | * VE.Smart | ||
* CAN-bus | * CAN-bus | ||
- | * CCGX/VGX - Referred | + | * GX device - collective name for CCGX, VGX, Cerbo GX and so on. |
- | * Equalisation | + | * equalisation |
+ | * Grid-connected - similar | ||
+ | * MultiPlus-II | ||
+ | * Node-RED | ||
+ | * Modbus-TCP | ||
+ | * Signal K (yes with that confusing space) | ||
+ | * run time - as in generator run time. not runtime or run-time | ||
Line 56: | Line 75: | ||
==== Style ==== | ==== Style ==== | ||
- | If in doubt //The Economist// has one of the best style guides I know of: http://www.economist.com/ | + | If in doubt //The Economist// has one of the best style guides I know of: https://shop.economist.com/ |
==== Type Faces Used ==== | ==== Type Faces Used ==== | ||
- | * MyriadPro-Bold | + | * Myriad Pro-Bold |
- | * MyriadPro-It | + | * Myriad Pro |
* Helvetica Neue regular, bold and condensed black | * Helvetica Neue regular, bold and condensed black | ||
* Arial regular and bold | * Arial regular and bold | ||
+ | ==== Units ==== | ||
+ | Use the International System of Units. for more info see [[https:// | ||
+ | ==== Victron Energy departments - names and definitions ==== | ||
+ | **Service Department** - Sometimes referred to as " | ||
+ | **Repair Centre** (previously called Service Partner) - These are external companies (customers) who perform product repairs on behalf of the Victron Energy Service Department. | ||
