drafts:victron_manual_of_style [2019-05-02 14:53] – [Language] justin_tyers_live_a_c | drafts:victron_manual_of_style [2024-03-07 09:44] (current) – [List of words that are often written incorrectly] guy_stewart | ||
Line 8: | Line 8: | ||
==== Language ==== | ==== Language ==== | ||
Use British English, as opposed to USA English. | Use British English, as opposed to USA English. | ||
- | The online version of the Oxford English Dictionary can be accessed [[http:// | ||
==== Numbers ==== | ==== Numbers ==== | ||
Line 28: | Line 27: | ||
* VE.Bus | * VE.Bus | ||
* VE.Can | * VE.Can | ||
+ | * VE.Smart | ||
* CAN-bus | * CAN-bus | ||
- | * CCGX/VGX - Referred to collectively as the Venus-device. | + | * GX device - collective name for CCGX, VGX, Cerbo GX and so on. |
- | * Equalization | + | * equalisation |
+ | * Grid-connected - similar to off-grid. | ||
+ | * MultiPlus-II | ||
+ | * Node-RED | ||
+ | * Modbus-TCP | ||
+ | * Signal K (yes with that confusing space) | ||
+ | * run time - as in generator run time. not runtime or run-time | ||
+ | ==== GX Product Classifications ==== | ||
- | ==== Spelling ==== | + | * GX product range - all GX devices (eg CCGX), |
- | There are several areas in which British | + | |
- | Ref: | + | * GX device |
+ | * GX Card - a circuit board featuring all the GX features that is used in the integrated products, eg EasySolar-II GX and MultiPlus-II GX. | ||
+ | Products that have the GX suffix are a GX device, or contain a GX device. | ||
+ | Products that have a GX prefix are accessories for a GX device. | ||
+ | Generally, public/ | ||
+ | Specific internal/ | ||
==== Style ==== | ==== Style ==== | ||
- | If in doubt //The Economist// has one of the best style guides I know of: http://www.economist.com/ | + | If in doubt //The Economist// has one of the best style guides I know of: https://shop.economist.com/ |
==== Type Faces Used ==== | ==== Type Faces Used ==== | ||
- | * MyriadPro-Bold | + | * Myriad Pro-Bold |
- | * MyriadPro-It | + | * Myriad Pro |
* Helvetica Neue regular, bold and condensed black | * Helvetica Neue regular, bold and condensed black | ||
* Arial regular and bold | * Arial regular and bold | ||
+ | ==== Units ==== | ||
+ | Use the International System of Units. for more info see [[https:// | ||
+ | ==== Victron Energy departments - names and definitions ==== | ||
+ | **Service Department** - Sometimes referred to as " | ||
+ | **Repair Centre** (previously called Service Partner) - These are external companies (customers) who perform product repairs on behalf of the Victron Energy Service Department. | ||
