drafts:victron_manual_of_style [2018-07-13 13:05] – [Product Acronyms] mvader | drafts:victron_manual_of_style [2022-09-13 11:02] – [List of words that are often written incorrectly] mvader | ||
The Victron Manual of Style (MoS), is a set of evolving and aspirational standards for the writing and design of documents. Victron' | The Victron Manual of Style (MoS), is a set of evolving and aspirational standards for the writing and design of documents. Victron' | ||
- | ===== A ===== | ||
==== Acronyms ==== | ==== Acronyms ==== | ||
Start a document with the full name of the acronym and then the acronym in brackets. Use just the acronym after that. Example: Battery Management System (BMS) and thereafter use just BMS. | Start a document with the full name of the acronym and then the acronym in brackets. Use just the acronym after that. Example: Battery Management System (BMS) and thereafter use just BMS. | ||
- | ===== L ===== | ||
==== Language ==== | ==== Language ==== | ||
- | Use US English, as opposed to UK English. | + | Use British |
- | ===== N ===== | + | |
==== Numbers ==== | ==== Numbers ==== | ||
Line 20: | Line 16: | ||
Ref: http:// | Ref: http:// | ||
- | ===== P ===== | ||
==== Punctuation ==== | ==== Punctuation ==== | ||
Line 32: | Line 27: | ||
- | List of words that are often written | + | ===== List of words that are often written |
* VE.Bus | * VE.Bus | ||
* VE.Can | * VE.Can | ||
+ | * VE.Smart | ||
* CAN-bus | * CAN-bus | ||
- | * CCGX/VGX - Referred to collectively as the Venus-device. | + | * GX device - collective name for CCGX, VGX, Cerbo GX and so on. |
+ | * equalisation | ||
+ | * Grid-connected - similar to off-grid. | ||
+ | * MultiPlus-II | ||
+ | * Node-RED | ||
+ | * Modbus-TCP | ||
+ | * Signal K (yes with that confusing space) | ||
+ | ==== GX Product Classifications ==== | ||
- | ===== S ===== | + | * GX product range - all GX devices (eg CCGX), |
- | ==== Spelling ==== | + | |
- | There are several areas in which British | + | |
- | Ref: | + | * GX device |
+ | * GX Card - a circuit board featuring all the GX features that is used in the integrated products, eg EasySolar-II GX and MultiPlus-II GX. | ||
+ | Products that have the GX suffix are a GX device, or contain a GX device. | ||
+ | Products that have a GX prefix are accessories for a GX device. | ||
+ | Generally, public/ | ||
+ | Specific internal/ | ||
==== Style ==== | ==== Style ==== | ||
- | If in doubt //The Economist// has one of the best style guides I know of: http://www.economist.com/ | + | If in doubt //The Economist// has one of the best style guides I know of: https://shop.economist.com/ |
+ | ==== Type Faces Used ==== | ||
+ | * Myriad Pro-Bold | ||
+ | * Myriad Pro | ||
+ | * Helvetica Neue regular, bold and condensed black | ||
+ | * Arial regular and bold | ||
+ | ==== Units ==== | ||
+ | Use the International System of Units. for more info see [[https:// | ||
+ | ==== Victron Energy departments - names and definitions ==== | ||
+ | **Service Department** - Sometimes referred to as " | ||
+ | **Repair Centre** (previously called Service Partner) - These are external companies (customers) who perform product repairs on behalf of the Victron Energy Service Department. | ||
