drafts:updater-error-codes
drafts:updater-error-codes [2019-09-09 13:23] – evandromr | drafts:updater-error-codes [2019-09-19 14:55] – evandromr | ||
==== Error codes ==== | ==== Error codes ==== | ||
- | In spite of our painstaking efforts, sometimes errors occur. In the following list, you can check possible errors and descriptions. | + | |
+ | In spite of our painstaking efforts, sometimes errors occur. | ||
+ | In most cases, errors are caused by communication problems. Always make sure to check all cable connections and, if you are using Bluetooth, stay as close to the product as possible. | ||
+ | Sometimes you may need to [[# | ||
+ | In the following list, you can check possible errors and descriptions. | ||
+ | Check [[# | ||
**VE.Direct products** | **VE.Direct products** | ||
Line 10: | Line 18: | ||
| D26 | Updating failed, communication lost. The product might be unusable. Check connection and power supply.\\ Try again and check the product settings once updated. | | | D26 | Updating failed, communication lost. The product might be unusable. Check connection and power supply.\\ Try again and check the product settings once updated. | | ||
| D29 | Could not start updating, the firmware file is corrupt. | | | D29 | Could not start updating, the firmware file is corrupt. | | ||
- | | D31 | Updating failed, product is unusable. Try again and check the product settings once updated. | | + | | D31 | Updating failed, |
| D32 | Could not start updating, entering boot mode failed. | | | D32 | Could not start updating, entering boot mode failed. | | ||
| D33 | Could not start updating, the firmware file is not found. | | | D33 | Could not start updating, the firmware file is not found. | | ||
- | | D90 | Could not start updating, firmware is not for this product. | | + | | D90 | Could not start updating, |
- | | D91 | Could not start updating, unknown product found. | | + | | D91 | Could not start updating, |
| D92 | Updating failed, erasing firmware failed. The product might be unusable. Try again and check the product settings once updated. | | | D92 | Updating failed, erasing firmware failed. The product might be unusable. Try again and check the product settings once updated. | | ||
| D93 | Error starting firmware after updating. Power cycle (off/on) your product and if that does not help\\ try updating again, and check the product settings once updated. | | | D93 | Error starting firmware after updating. Power cycle (off/on) your product and if that does not help\\ try updating again, and check the product settings once updated. | | ||
- | | D94 | + | | D94 |
- | | D95 | Product updated successfully, | + | | D95 | Product updated successfully, |
- | | D96 | Updating failed due to version | + | | D96 | Updating failed due to version |
| D97 | Dup executable too old. | | | D97 | Dup executable too old. | | ||
| D98 | Firmware file is not a valid dup file. | | | D98 | Firmware file is not a valid dup file. | | ||
Line 37: | Line 45: | ||
| B9 | Timeout waiting for access to the Dfu BLE service. | | | B9 | Timeout waiting for access to the Dfu BLE service. | | ||
| B10 | Timeout waiting for a response. | | | B10 | Timeout waiting for a response. | | ||
- | | B11 | Timeout while writing to the product. Perhaps a pairing | + | | B11 | Timeout while writing to the product. Perhaps a pairing |
+ | | B12 | Device was no longer found. Perhaps out of range? Please retry. | | ||
| B96 | An internal error occurred (Opcode not supported). Please send a service report to Victron Energy. | | | B96 | An internal error occurred (Opcode not supported). Please send a service report to Victron Energy. | | ||
| B97 | The requested encryption is not supported by the product. Please send a service report to Victron Energy. | | | B97 | The requested encryption is not supported by the product. Please send a service report to Victron Energy. | | ||
Line 46: | Line 55: | ||
| B102 | An internal error occurred (Not allowed). Please send a service report to Victron Energy. | | | B102 | An internal error occurred (Not allowed). Please send a service report to Victron Energy. | | ||
- | ** XUP - files ** | + | ** VE.Bus Products ** |
+ | ^Error ^Description^ | ||
+ | |V2 | No product detected. Please check all the cable connections and try again.| | ||
+ | |V3 | An unexpected timeout was triggered. Please check all the cable connections and try again.| | ||
+ | |V4 | Incomplete vff file. Nonce missing. Please make sure you selected a valid update file and try again.| | ||
+ | |V5 | Incomplete vff file. EEPROM lines missing. Please make sure you selected a valid update file and try again.| | ||
+ | |V6 | The vff file contains more eeprom data than supported. Please make sure you selected a valid update file and try again.| | ||
+ | |V7 | The calibration map in the file exceeds the device calibration map. Please make sure you selected a valid update file and try again.| | ||
+ | |V8 | Device calibration data size bigger than expected. Please make sure you selected a valid update file and try again.| | ||
+ | |V9 | Bootloader did not respond to bootloader setup. Please check all the cable connections and try again.| | ||
+ | |V10 | Bootloader response to version request failed.| | ||
+ | |V11 | Incompatible bootblock. Function version invalid.| | ||
+ | |V12 | Incompatible bootblock. Version invalid.| | ||
+ | |V13 | Bootloader did not start after bootblock update.| | ||
+ | |V14 | Incompatible bootblock type.| | ||
+ | |V15 | No or unexpected response to target id query.| | ||
+ | |V16 | No or unexpected response to eeprom read action.| | ||
+ | |V17 | No or unexpected response to calibration map query.| | ||
+ | |V18 | The supplied firmware contains new unsupported calibration values. \\ The updater does not know how to handle them.| | ||
+ | |V19 | No response received to eeprom write command. Please check all the cable connections and try again.| | ||
+ | |V20 | Invalid response received to eeprom write command. Please check all the cable connections and try again.| | ||
+ | |V21 | No response received to code write command. Please check all the cable connections and try again.| | ||
+ | |V22 | Invalid response received to code write command.| | ||
+ | |V23 | The MK2/MK3 did not respond. Please check all the cable connections and try again.| | ||
+ | |V24 | The connected product does not match the specified model in the file. \\ Please make sure you selected a valid update file and try again.| | ||
+ | |V25 | The hardware revision specific eeprom defaults data is corrupt. \\ Please make sure you selected a valid update file and try again.| | ||
+ | |V26 | Updates can not be performed with a VEBUS BMS connected.| | ||
+ | |V27 | Updates can not be performed with a DMC connected.| | ||
+ | |V40 | Failed to start Update. could not allocate memory. Malloc error.| | ||
+ | |V50 | Failed to start Update. File open error. Please check the file location and access permissions.\\ Make sure you selected a valid update file and try again.| | ||
+ | |V51 | Failed to start Update. File write error. Please check file location and access permissions.\\ Make sure you selected a valid update file and try again.| | ||
+ | |V52 | Failed to start Update. File read error. Please check file location and access permissions.\\ Make sure you selected a valid update file and try again.| | ||
+ | |V53 | Failed to start Update. File checksum error. File corrupted or not a valid VFF file.\\ Please make sure you selected a valid update file and try again.| | ||
+ | |V54 | Failed to start Update. File has an incompatible version number.\\ Please make sure you selected a valid update file and try again.| | ||
+ | |V55 | Failed to start Update. File section not found. File corrupted or not a valid VFF file.\\ Please make sure you selected a valid update file and try again.| | ||
+ | |V56 | Failed to start Update. Format error. File corrupted or not a valid VFF file.\\ Please make sure you selected a valid update file and try again.| | ||
+ | ** All other products (XUP update | ||
^Error ^Description^ | ^Error ^Description^ | ||
- | |X1 |Successful| | ||
- | |X2 |Generic Failure. Please try again.| | ||
|X3 |Invalid updater state. Please try again.| | |X3 |Invalid updater state. Please try again.| | ||
|X4 |Firmware not for Product (Id). Please make sure you selected a valid update file and try again.| | |X4 |Firmware not for Product (Id). Please make sure you selected a valid update file and try again.| | ||
- | |X5 |Updater (version) too old.") } | + | |X5 |Updater (version) too old. | |
|X6 |Communication Error. No Callback handler connected. Please check the connection and try again.| | |X6 |Communication Error. No Callback handler connected. Please check the connection and try again.| | ||
- | |X7 |Communication Error. Vreg ack-ed with unexpected error. | + | |X7 |Communication Error. Vreg ack-ed with an unexpected error. |
|X8 |Update (xup) file format not supported. Please make sure you selected a valid update file and try again.| | |X8 |Update (xup) file format not supported. Please make sure you selected a valid update file and try again.| | ||
- | |X9 |File Error. No Instance Blob could be found in update file. Please make sure you selected a valid update file and try again.| | + | |X9 |File Error. No Instance Blob could be found in the update file. Please make sure you selected a valid update file and try again.| |
|X10 |File Error. Invalid instance Blob attribute. Please make sure you selected a valid update file and try again.| | |X10 |File Error. Invalid instance Blob attribute. Please make sure you selected a valid update file and try again.| | ||
|X11 |File Error. Instance Blob defined more than once. Please make sure you selected a valid update file and try again.| | |X11 |File Error. Instance Blob defined more than once. Please make sure you selected a valid update file and try again.| | ||
- | |X12 |File Error. No Firmware Version for instance found in update file. Please make sure you selected a valid update file and try again.| | + | |X12 |File Error. No Firmware Version for instance found in the update file. Please make sure you selected a valid update file and try again.| |
|X13 |Communication Error. Unexpected Vreg Ack received. Please check the connection and try again.| | |X13 |Communication Error. Unexpected Vreg Ack received. Please check the connection and try again.| | ||
- | |X14 |Communication Error. | + | |X14 |Communication Error. |
|X15 |Fail on Minimum Firmware Version check. Please make sure you selected a valid update file and try again.| | |X15 |Fail on Minimum Firmware Version check. Please make sure you selected a valid update file and try again.| | ||
|X16 |Failed to Begin Update. Please check the connection and try again.| | |X16 |Failed to Begin Update. Please check the connection and try again.| | ||
- | |X17 |File Error. No/invalid Firmware data found for instance in update file. Please make sure you selected a valid update file and try again.| | + | |X17 |File Error. No/invalid Firmware data found for instance in the update file. Please make sure you selected a valid update file and try again.| |
|X18 |Update Error. Invalid ack on non-final Update Data. Please check the connection and try again.| | |X18 |Update Error. Invalid ack on non-final Update Data. Please check the connection and try again.| | ||
|X19 |Update Error. Invalid sequence# in Update Data Ack. Please check the connection and try again.| | |X19 |Update Error. Invalid sequence# in Update Data Ack. Please check the connection and try again.| | ||
Line 73: | Line 118: | ||
|X24 |Verification Error. Invalid instance field in Minimum Firmware Version Ack. Please check the connection and try again.| | |X24 |Verification Error. Invalid instance field in Minimum Firmware Version Ack. Please check the connection and try again.| | ||
|X25 |Verification Error. Invalid instance field in Firmware Version Ack. Please check the connection and try again.| | |X25 |Verification Error. Invalid instance field in Firmware Version Ack. Please check the connection and try again.| | ||
- | |X26 |Verification Error. Invalid instance field in UDF Version Ack. Please check the connection and try again.| | + | |X26 |Verification Error. Invalid instance field in UDF Version Ack.\\ Please check the connection and try again.| |
- | |X27 |Failed to verify Minimum Firmware Version. Please check the connection and try again.| | + | |X27 |Failed to verify Minimum Firmware Version.\\ Please check the connection and try again.| |
|X28 |Failed to verify Firmware Version. Please check the connection and try again.| | |X28 |Failed to verify Firmware Version. Please check the connection and try again.| | ||
|X29 |Failed to verify UDF Version. Please check the connection and try again.| | |X29 |Failed to verify UDF Version. Please check the connection and try again.| | ||
|X30 |Failed on Minimum Firmware Version verification. Please check the connection and try again.| | |X30 |Failed on Minimum Firmware Version verification. Please check the connection and try again.| | ||
|X31 |Failed on Firmware Version verification. Please check the connection and try again.| | |X31 |Failed on Firmware Version verification. Please check the connection and try again.| | ||
- | |X32 |Still in Bootloader Mode after update. Please try again.| | + | |X32 |Still in Bootloader Mode after the update. Please try again.| |
- | |X33 |File Error. No Product Id found in update file. Please make sure you selected a valid update file and try again.| | + | |X33 |File Error. No Product Id found in the update file. Please make sure you selected a valid update file and try again.| |
- | |X34 |File Error. No VE.Direct baudrates found in update file. Please make sure you selected a valid update file and try again.| | + | |X34 |File Error. No VE.Direct baudrates found in the update file. Please make sure you selected a valid update file and try again.| |
- | |X35 |File Error. No Xup Format Version found in update file. Please make sure you selected a valid update file and try again.| | + | |X35 |File Error. No Xup Format Version found in the update file. Please make sure you selected a valid update file and try again.| |
- | |X36 |File Error. No Minimum Updater Version found in update file. Please make sure you selected a valid update file and try again.| | + | |X36 |File Error. No Minimum Updater Version found in the update file. Please make sure you selected a valid update file and try again.| |
- | |X37 |File Error. No Firmware (product) Version found in update file. Please make sure you selected a valid update file and try again.| | + | |X37 |File Error. No Firmware (product) Version found in the update file. Please make sure you selected a valid update file and try again.| |
- | |X38 |File Error. | + | |X38 |File Error. |
|X39 |Communication Error. Vreg Ack timeout. Please check the connection and try again.| | |X39 |Communication Error. Vreg Ack timeout. Please check the connection and try again.| | ||
|X40 |Communication Error. No product found. Please check the connection and try again.| | |X40 |Communication Error. No product found. Please check the connection and try again.| | ||
Line 94: | Line 139: | ||
|X45 |Update Error. Vreg Ack error: Invalid instance. Please check the connection and try again.| | |X45 |Update Error. Vreg Ack error: Invalid instance. Please check the connection and try again.| | ||
|X46 |Update Error. Vreg Ack error. Please check the connection and try again.| | |X46 |Update Error. Vreg Ack error. Please check the connection and try again.| | ||
drafts/updater-error-codes.txt · Last modified: 2019-09-20 11:05 by evandromr
