dc_distribution
dc_distribution [2020-01-12 12:42] – guy_stewart | dc_distribution [2021-02-15 15:23] – [Installation] mvader | ||
Line 70: | Line 70: | ||
When all is OK, only the central LED is green; when a fuse has blown (or is missing) the central and blow fuse circuit LEDs turn red. If you are not using all connection points in your DC distribution, | When all is OK, only the central LED is green; when a fuse has blown (or is missing) the central and blow fuse circuit LEDs turn red. If you are not using all connection points in your DC distribution, | ||
- | A future upgrade is planned to also send info back to the GX device over the VE-can, but is not yet implemented. | ||
==== Fuses ==== | ==== Fuses ==== | ||
Uses MEGA fuses. Please note that some MEGA fuses are only rated to 36Volt (suitable for 24V systems), You must use 58/64V rated fuses for 48V systems. | Uses MEGA fuses. Please note that some MEGA fuses are only rated to 36Volt (suitable for 24V systems), You must use 58/64V rated fuses for 48V systems. | ||
Line 93: | Line 90: | ||
A - That’s for manual settings, please don’t touch as the system will auto configure (up to 32 battery’s ) | A - That’s for manual settings, please don’t touch as the system will auto configure (up to 32 battery’s ) | ||
- | Q - The Distributor has a 6-pin header block. What is it for? | ||
- | A - In the future, the read out of fuses, but this is not supported yet. | ||
dc_distribution.txt · Last modified: 2021-04-19 08:55 by marmour
