ccgx:root_access
ccgx:root_access [2020-05-28 15:49] – [Available disk space] mvader | ccgx:root_access [2020-06-28 10:35] – mvader | ||
Line 98: | Line 98: | ||
https:// | https:// | ||
- | ==== 6. Connecting | + | ==== 6. Connecting |
- | First, note that this is only relevant for the CCGX, as the Beagleboards have a uart dedicated to a console function. | + | === Introduction === |
- | See menu item Settings -> Services -> Console | + | The serial console offers a straight connection from your computer. Not relying |
- | Enable | + | Its an alternative to connecting to the commandline over ssh. |
- | Settings are 115k2 / 8N1. Note that a normal VE.Direct to USB interface | + | Connecting to the serial console requires |
+ | The serial consoles on all GX devices are configured to 115200 baud. | ||
+ | === Serial console on CCGX === | ||
- | ===== DISQUS | + | All GX Devices have a dedicated serial console, except for the CCGX. Therefor its documented on a separate page: |
- | ~~DISQUS~~ | + | |
+ | === Serial Console on Cerbo GX === | ||
+ | The serial console is located on the CPU board, header JP201. GND is pin 1, RX and TX are pins 4 and 5. Here is a picture showing a [[https:// | ||
+ | Make sure not to connect the red wire. | ||
+ | === Serial Console on Venus GX === | ||
+ | The serial console is located on the base-board, and can be accessed through the slot between that board and the Ethernet connector on the beaglebone-board. | ||
+ | White: TX of the Beaglebone - connect to RX on your cable | ||
+ | Black: ground | ||
+ | Green: RX of the Beaglebone - connect to TX on your cable | ||
+ | Here is a picture showing how, also using the adafruit serial console cable as referenced above: | ||
ccgx/root_access.txt · Last modified: 2024-02-09 17:06 by dfaber
