ccgx:firmware_upgrade_to_v2
ccgx:firmware_upgrade_to_v2 [2017-01-16 21:24] – mvader | ccgx:firmware_upgrade_to_v2 [2021-02-08 22:30] (current) – latest upgrade is 2.18 not 2.11 doc_nl | ||
- | ====== CCGX: Upgrading to v2.00 ====== | + | ====== CCGX: Upgrading to v2 ====== |
- | Unlike previous updates, v2.00 can not be installed | + | ===== Introduction ===== |
+ | Updating a CCGX from v1.74 to a newer version requires | ||
+ | This document explains how to do the manual upgrade. | ||
+ | Once upgraded, updates can be installed | ||
+ | ===== Upgrade procedure ===== | ||
+ | {{youtube> | ||
A microSD card is needed. It is not possible to use an USB stick. | A microSD card is needed. It is not possible to use an USB stick. | ||
Line 9: | Line 18: | ||
+ | - Get a microSD card. The card needs to be formatted with either a FAT or FAT32 file system. Preferably use a card of 32GB or smaller, as larger cards are often hard to format with mentioned FAT file systems. The upgrade requires less than 150MB on the card. | ||
- Download [[https:// | - Download [[https:// | ||
- | - Unzip it, and put its contents on a microSD | + | |
- Click ‘Safely remove hardware’ or another eject function on your computer. | - Click ‘Safely remove hardware’ or another eject function on your computer. | ||
- Take the card out | - Take the card out | ||
Line 22: | Line 33: | ||
- So, remove the card, and press buttons A and B again to reboot. | - So, remove the card, and press buttons A and B again to reboot. | ||
- | Upgrade complete | + | Upgrade |
* All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | ||
* Also all settings in the ccgx won’t be affected. But still it is good to double check that. | * Also all settings in the ccgx won’t be affected. But still it is good to double check that. | ||
* Especially double check wifi and/or ethernet passwords and IP configuration. | * Especially double check wifi and/or ethernet passwords and IP configuration. | ||
- | + | * There are additional versions of VenusOS | |
- | For developers and people | + | |
===== Troubleshooting ===== | ===== Troubleshooting ===== | ||
- | === It restart normally and doesn' | + | === It reboots but doesn' |
- | Make sure to hold (!) button E till the upgrade starts | + | |
+ | Solution: | ||
=== A blue screen is shown while booting and after ~1 minute, " | === A blue screen is shown while booting and after ~1 minute, " | ||
Line 52: | Line 63: | ||
This means that the button pressing procedure was done OK. And the sdcard is properly formatted. | This means that the button pressing procedure was done OK. And the sdcard is properly formatted. | ||
- | Two possible | + | Possible |
- | - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard | + | |
- | - the sdcard slot in the CCGX is broken | + | |
- | ~~DISQUS~~ | + | - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard; |
+ | - the sdcard slot in the CCGX is broken: contact your dealer for a replacement; | ||
+ | - A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus. |
ccgx/firmware_upgrade_to_v2.1484598244.txt.gz · Last modified: 2017-01-16 21:24 by mvader
