ccgx:firmware_upgrade_to_v2
| ccgx:firmware_upgrade_to_v2 [2020-07-22 08:13] – mvader | ccgx:firmware_upgrade_to_v2 [2021-02-08 21:30] (current) – latest upgrade is 2.18 not 2.11 doc_nl | ||
| Line 33: | Line 33: | ||
| - So, remove the card, and press buttons A and B again to reboot. | - So, remove the card, and press buttons A and B again to reboot. | ||
| - | Upgrade complete | + | Upgrade |
| * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | ||
| * Also all settings in the ccgx won’t be affected. But still it is good to double check that. | * Also all settings in the ccgx won’t be affected. But still it is good to double check that. | ||
| * Especially double check wifi and/or ethernet passwords and IP configuration. | * Especially double check wifi and/or ethernet passwords and IP configuration. | ||
| + | * There are additional versions of VenusOS that have been released since this update image. To finish updating to the latest version, you can now follow the normal [[ccgx: | ||
| ===== Troubleshooting ===== | ===== Troubleshooting ===== | ||
ccgx/firmware_upgrade_to_v2.1595405619.txt.gz · Last modified: by mvader
