ccgx:firmware_upgrade_to_v2
ccgx:firmware_upgrade_to_v2 [2020-06-30 21:33] – [CCGX: Upgrading to v2] mvaderccgx:firmware_upgrade_to_v2 [2021-02-08 21:30] (current) – latest upgrade is 2.18 not 2.11 doc_nl
Line 6: Line 6:
 This document explains how to do the manual upgrade. This document explains how to do the manual upgrade.
-Once upgraded, updates can be installed automatically from the internet again. See [[https://www.victronenergy.com/live/ccgx:firmware_updating|here]] for how to that (after performing this one time manual update).+Once upgraded, updates can be installed normally again. Procedure for normal firmware updates is in [[https://www.victronenergy.com/media/pg/2556-GX_Device_Manual_CCGX/en/updating-gx-firmware.html|the Color Control GX Manual]].
 ===== Upgrade procedure ===== ===== Upgrade procedure =====
Line 33: Line 33:
   - So, remove the card, and press buttons A and B again to reboot.   - So, remove the card, and press buttons A and B again to reboot.
-Upgrade complete already! But make sure to double check a few things:+Upgrade from 1.x to 2.18 is now complete! But make sure to double check a few things:
   * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected.   * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected.
   * Also all settings in the ccgx won’t be affected. But still it is good to double check that.   * Also all settings in the ccgx won’t be affected. But still it is good to double check that.
   * Especially double check wifi and/or ethernet passwords and IP configuration.   * Especially double check wifi and/or ethernet passwords and IP configuration.
 +  * There are additional versions of VenusOS that have been released since this update image. To finish updating to the latest version, you can now follow the normal [[ccgx:firmware_updating|version 2.x firmware update instructions here. ]]
 ===== Troubleshooting ===== ===== Troubleshooting =====
Line 67: Line 68:
   - the sdcard slot in the CCGX is broken: contact your dealer for a replacement;   - the sdcard slot in the CCGX is broken: contact your dealer for a replacement;
   - A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus.   - A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus.
-===== DISQUS =====
-~~DISQUS~~
ccgx/firmware_upgrade_to_v2.1593552821.txt.gz · Last modified: by mvader
