ccgx:firmware_upgrade_to_v2
| ccgx:firmware_upgrade_to_v2 [2019-01-21 09:59] – [DISQUS] ictbeheer | ccgx:firmware_upgrade_to_v2 [2021-02-08 21:30] (current) – latest upgrade is 2.18 not 2.11 doc_nl | ||
| Line 1: | Line 1: | ||
| ====== CCGX: Upgrading to v2 ====== | ====== CCGX: Upgrading to v2 ====== | ||
| - | Updating a CCGX from v1.74 to a newer version requires a one time manual upgrade. | + | ===== Introduction ===== |
| + | Updating a CCGX from v1.74 to a newer version requires a one time manual upgrade. | ||
| - | At this moment, | + | This document explains how to do the manual upgrade. |
| - | Once upgraded, updates can be installed | + | Once upgraded, updates can be installed |
| - | . | + | ===== Upgrade procedure ===== |
| {{youtube> | {{youtube> | ||
| Line 32: | Line 33: | ||
| - So, remove the card, and press buttons A and B again to reboot. | - So, remove the card, and press buttons A and B again to reboot. | ||
| - | Upgrade complete | + | Upgrade |
| * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | ||
| * Also all settings in the ccgx won’t be affected. But still it is good to double check that. | * Also all settings in the ccgx won’t be affected. But still it is good to double check that. | ||
| * Especially double check wifi and/or ethernet passwords and IP configuration. | * Especially double check wifi and/or ethernet passwords and IP configuration. | ||
| + | * There are additional versions of VenusOS that have been released since this update image. To finish updating to the latest version, you can now follow the normal [[ccgx: | ||
| ===== Troubleshooting ===== | ===== Troubleshooting ===== | ||
| - | === It restart normally and doesn' | + | === It reboots but doesn' |
| - | Make sure to hold (!) button E till the upgrade starts | + | |
| + | Solution: | ||
| === A blue screen is shown while booting and after ~1 minute, " | === A blue screen is shown while booting and after ~1 minute, " | ||
| Line 62: | Line 65: | ||
| Possible causes: | Possible causes: | ||
| - | - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard | + | - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard; |
| - | - the sdcard slot in the CCGX is broken: contact your dealer for a replacement | + | - the sdcard slot in the CCGX is broken: contact your dealer for a replacement; |
| - A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus. | - A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus. | ||
ccgx/firmware_upgrade_to_v2.1548064782.txt.gz · Last modified: by ictbeheer
