ccgx:firmware_upgrade_to_v2
ccgx:firmware_upgrade_to_v2 [2018-02-15 14:53] – markkuccgx:firmware_upgrade_to_v2 [2021-02-08 21:30] (current) – latest upgrade is 2.18 not 2.11 doc_nl
 ====== CCGX: Upgrading to v2 ====== ====== CCGX: Upgrading to v2 ======
-Updating a CCGX from v1.74 to a newer version requires a one time manual upgrade.+===== Introduction =====
 +Updating a CCGX from v1.74 to a newer version requires a one time manual upgrade. It can’t be done automatically.
-At this moment, the latest available version is v2.11.+This document explains how to do the manual upgrade.
-This document explains the one time manual upgrade procedure.+Once upgraded, updates can be installed normally again. Procedure for normal firmware updates is in [[https://www.victronenergy.com/media/pg/2556-GX_Device_Manual_CCGX/en/updating-gx-firmware.html|the Color Control GX Manual]].
-Once upgraded, updates can be installed automatically from the internet again. See [[https://www.victronenergy.com/live/ccgx:firmware_updating|here]] for details. +===== Upgrade procedure =====
 {{youtube>T-qK9f6FlmU?medium}} {{youtube>T-qK9f6FlmU?medium}}
Line 19: Line 18:
 {{ :ccgx:card.png?nolink&200|}} {{ :ccgx:card.png?nolink&200|}}
-  - Get a microSD card. The card needs to be formatted with either a FAT or FAT32 file system. Preferably use a card of 32GB or smaller, as larger cards are often hard to format with mentioned FAT filesystems. The upgrade requires less than 150MB on the card.+  - Get a microSD card. The card needs to be formatted with either a FAT or FAT32 file system. Preferably use a card of 32GB or smaller, as larger cards are often hard to format with mentioned FAT file systems. The upgrade requires less than 150MB on the card.
   - Download [[https://updates.victronenergy.com/feeds/venus/release/images/ccgx/venus-upgrade-image-ccgx.zip|venus-upgrade-image-ccgx.zip]]   - Download [[https://updates.victronenergy.com/feeds/venus/release/images/ccgx/venus-upgrade-image-ccgx.zip|venus-upgrade-image-ccgx.zip]]
   - Above link always points to the latest available version.   - Above link always points to the latest available version.
Line 34: Line 33:
   - So, remove the card, and press buttons A and B again to reboot.   - So, remove the card, and press buttons A and B again to reboot.
-Upgrade complete already! But make sure to double check a few things:+Upgrade from 1.x to 2.18 is now complete! But make sure to double check a few things:
   * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected.   * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected.
   * Also all settings in the ccgx won’t be affected. But still it is good to double check that.   * Also all settings in the ccgx won’t be affected. But still it is good to double check that.
   * Especially double check wifi and/or ethernet passwords and IP configuration.   * Especially double check wifi and/or ethernet passwords and IP configuration.
 +  * There are additional versions of VenusOS that have been released since this update image. To finish updating to the latest version, you can now follow the normal [[ccgx:firmware_updating|version 2.x firmware update instructions here. ]]
 ===== Troubleshooting ===== ===== Troubleshooting =====
-=== It restart normally and doesn't start the upgrade === +=== It reboots but doesn't start the upgrade; instead it does a normal boot ===
-Make sure to hold (!) button E till the upgrade starts+
 +Solution: Make sure to hold (!) button E till the upgrade starts
 === A blue screen is shown while booting and after ~1 minute, "Starting" is displayed === === A blue screen is shown while booting and after ~1 minute, "Starting" is displayed ===
Line 62: Line 63:
 This means that the button pressing procedure was done OK. And the sdcard is properly formatted. This means that the button pressing procedure was done OK. And the sdcard is properly formatted.
-Possible causes +Possible causes:
-  - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard +
-  - the sdcard slot in the CCGX is broken: contact your dealer for a replacement +
-===== DISQUS =====+
-~~DISQUS~~+  - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard;
 +  - the sdcard slot in the CCGX is broken: contact your dealer for a replacement;
 +  - A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus.
ccgx/firmware_upgrade_to_v2.1518706420.txt.gz · Last modified: by markku
