ccgx:firmware_upgrade_to_v2
| ccgx:firmware_upgrade_to_v2 [2017-08-25 16:31] – [CCGX: Upgrading to v2] mvader | ccgx:firmware_upgrade_to_v2 [2021-02-08 21:30] (current) – latest upgrade is 2.18 not 2.11 doc_nl | ||
| Line 1: | Line 1: | ||
| ====== CCGX: Upgrading to v2 ====== | ====== CCGX: Upgrading to v2 ====== | ||
| - | After v1.74, the next version is v2.00. Installing v2.00 (or later) on a CCGX with version | + | ===== Introduction ===== |
| + | Updating a CCGX from v1.74 to a newer version requires a one time manual upgrade. It can’t be done automatically. | ||
| - | This document explains | + | This document explains |
| - | After the one time manual upgrade, updates can be installed | + | Once upgraded, updates can be installed |
| - | . | + | ===== Upgrade procedure ===== |
| {{youtube> | {{youtube> | ||
| Line 17: | Line 18: | ||
| + | - Get a microSD card. The card needs to be formatted with either a FAT or FAT32 file system. Preferably use a card of 32GB or smaller, as larger cards are often hard to format with mentioned FAT file systems. The upgrade requires less than 150MB on the card. | ||
| - Download [[https:// | - Download [[https:// | ||
| - | - Unzip it, and put its contents on a microSD | + | |
| - Click ‘Safely remove hardware’ or another eject function on your computer. | - Click ‘Safely remove hardware’ or another eject function on your computer. | ||
| - Take the card out | - Take the card out | ||
| Line 30: | Line 33: | ||
| - So, remove the card, and press buttons A and B again to reboot. | - So, remove the card, and press buttons A and B again to reboot. | ||
| - | Upgrade complete | + | Upgrade |
| * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | ||
| * Also all settings in the ccgx won’t be affected. But still it is good to double check that. | * Also all settings in the ccgx won’t be affected. But still it is good to double check that. | ||
| * Especially double check wifi and/or ethernet passwords and IP configuration. | * Especially double check wifi and/or ethernet passwords and IP configuration. | ||
| - | + | * There are additional versions of VenusOS | |
| - | For developers and people | + | |
| ===== Troubleshooting ===== | ===== Troubleshooting ===== | ||
| - | === It restart normally and doesn' | + | === It reboots but doesn' |
| - | Make sure to hold (!) button E till the upgrade starts | + | |
| + | Solution: | ||
| === A blue screen is shown while booting and after ~1 minute, " | === A blue screen is shown while booting and after ~1 minute, " | ||
| Line 60: | Line 63: | ||
| This means that the button pressing procedure was done OK. And the sdcard is properly formatted. | This means that the button pressing procedure was done OK. And the sdcard is properly formatted. | ||
| - | Two possible | + | Possible |
| - | - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard | + | |
| - | - the sdcard slot in the CCGX is broken: contact your dealer for a replacement | + | |
| - | ===== DISQUS ===== | + | |
| - | ~~DISQUS~~ | + | - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard; |
| + | - the sdcard slot in the CCGX is broken: contact your dealer for a replacement; | ||
| + | - A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus. | ||
ccgx/firmware_upgrade_to_v2.1503678664.txt.gz · Last modified: by mvader
