ccgx:firmware_upgrade_to_v2
ccgx:firmware_upgrade_to_v2 [2020-07-22 10:13] – mvader | ccgx:firmware_upgrade_to_v2 [2020-10-09 02:04] – [Upgrade procedure] guy_stewart | ||
Line 33: | Line 33: | ||
- So, remove the card, and press buttons A and B again to reboot. | - So, remove the card, and press buttons A and B again to reboot. | ||
- | Upgrade complete | + | Upgrade |
* All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | ||
* Also all settings in the ccgx won’t be affected. But still it is good to double check that. | * Also all settings in the ccgx won’t be affected. But still it is good to double check that. | ||
* Especially double check wifi and/or ethernet passwords and IP configuration. | * Especially double check wifi and/or ethernet passwords and IP configuration. | ||
+ | * There are additional versions of VenusOS that have been released since this update image. To finish updating to the latest version, you can now follow the normal [[ccgx: | ||
===== Troubleshooting ===== | ===== Troubleshooting ===== |
ccgx/firmware_upgrade_to_v2.txt · Last modified: 2021-02-08 22:30 by doc_nl
