ccgx:firmware_upgrade_to_v2
ccgx:firmware_upgrade_to_v2 [2020-06-30 23:33] – [CCGX: Upgrading to v2] mvader | ccgx:firmware_upgrade_to_v2 [2020-10-09 02:04] – [Upgrade procedure] guy_stewart | ||
Line 6: | Line 6: | ||
This document explains how to do the manual upgrade. | This document explains how to do the manual upgrade. | ||
- | Once upgraded, updates can be installed | + | Once upgraded, updates can be installed |
===== Upgrade procedure ===== | ===== Upgrade procedure ===== | ||
Line 33: | Line 33: | ||
- So, remove the card, and press buttons A and B again to reboot. | - So, remove the card, and press buttons A and B again to reboot. | ||
- | Upgrade complete | + | Upgrade |
* All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | ||
* Also all settings in the ccgx won’t be affected. But still it is good to double check that. | * Also all settings in the ccgx won’t be affected. But still it is good to double check that. | ||
* Especially double check wifi and/or ethernet passwords and IP configuration. | * Especially double check wifi and/or ethernet passwords and IP configuration. | ||
+ | * There are additional versions of VenusOS that have been released since this update image. To finish updating to the latest version, you can now follow the normal [[ccgx: | ||
===== Troubleshooting ===== | ===== Troubleshooting ===== | ||
Line 67: | Line 68: | ||
- the sdcard slot in the CCGX is broken: contact your dealer for a replacement; | - the sdcard slot in the CCGX is broken: contact your dealer for a replacement; | ||
- A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus. | - A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus. | ||
- | ~~DISQUS~~ | ||
ccgx/firmware_upgrade_to_v2.txt · Last modified: 2021-02-08 22:30 by doc_nl
