ccgx:firmware_upgrade_to_v2
ccgx:firmware_upgrade_to_v2 [2019-01-22 10:16] – external edit 127.0.0.1 | ccgx:firmware_upgrade_to_v2 [2020-06-30 23:33] – [CCGX: Upgrading to v2] mvader | ||
====== CCGX: Upgrading to v2 ====== | ====== CCGX: Upgrading to v2 ====== | ||
- | Updating a CCGX from v1.74 to a newer version requires a one time manual upgrade. | + | ===== Introduction ===== |
+ | Updating a CCGX from v1.74 to a newer version requires a one time manual upgrade. | ||
- | At this moment, | + | This document explains how to do the manual upgrade. |
- | Once upgraded, updates can be installed automatically from the internet again. See [[https:// | + | Once upgraded, updates can be installed automatically from the internet again. See [[https:// |
- | . | + | ===== Upgrade procedure ===== |
{{youtube> | {{youtube> | ||
Line 40: | Line 41: | ||
===== Troubleshooting ===== | ===== Troubleshooting ===== | ||
- | === It restart normally and doesn' | + | === It reboots but doesn' |
- | Make sure to hold (!) button E till the upgrade starts | + | |
+ | Solution: | ||
=== A blue screen is shown while booting and after ~1 minute, " | === A blue screen is shown while booting and after ~1 minute, " | ||
Line 62: | Line 64: | ||
Possible causes: | Possible causes: | ||
- | - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard | + | - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard; |
- | - the sdcard slot in the CCGX is broken: contact your dealer for a replacement | + | - the sdcard slot in the CCGX is broken: contact your dealer for a replacement; |
- A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus. | - A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus. | ||
ccgx/firmware_upgrade_to_v2.txt · Last modified: 2021-02-08 22:30 by doc_nl
