ccgx:firmware_upgrade_to_v2
ccgx:firmware_upgrade_to_v2 [2018-02-15 15:53] – markku | ccgx:firmware_upgrade_to_v2 [2019-01-21 10:59] – [DISQUS] ictbeheer | ||
====== CCGX: Upgrading to v2 ====== | ====== CCGX: Upgrading to v2 ====== | ||
- | Updating a CCGX from v1.74 to a newer version requires a one time manual upgrade. | + | Updating a CCGX from v1.74 to a newer version requires a one time manual upgrade. This document explains how thats done. |
- | At this moment, the latest available version is v2.11. | + | At this moment, the latest available version is v2.12. |
- | This document explains the one time manual upgrade procedure. | + | |
Once upgraded, updates can be installed automatically from the internet again. See [[https:// | Once upgraded, updates can be installed automatically from the internet again. See [[https:// | ||
Line 19: | Line 17: | ||
- | - Get a microSD card. The card needs to be formatted with either a FAT or FAT32 file system. Preferably use a card of 32GB or smaller, as larger cards are often hard to format with mentioned FAT filesystems. The upgrade requires less than 150MB on the card. | + | - Get a microSD card. The card needs to be formatted with either a FAT or FAT32 file system. Preferably use a card of 32GB or smaller, as larger cards are often hard to format with mentioned FAT file systems. The upgrade requires less than 150MB on the card. |
- Download [[https:// | - Download [[https:// | ||
- Above link always points to the latest available version. | - Above link always points to the latest available version. | ||
Line 62: | Line 60: | ||
This means that the button pressing procedure was done OK. And the sdcard is properly formatted. | This means that the button pressing procedure was done OK. And the sdcard is properly formatted. | ||
- | Possible causes | + | Possible causes: |
- the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard | - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard | ||
- the sdcard slot in the CCGX is broken: contact your dealer for a replacement | - the sdcard slot in the CCGX is broken: contact your dealer for a replacement | ||
+ | - A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus. | ||
ccgx/firmware_upgrade_to_v2.txt · Last modified: 2021-02-08 22:30 by doc_nl
