ccgx:firmware_upgrade_to_v2
ccgx:firmware_upgrade_to_v2 [2018-02-12 16:45] – [Troubleshooting] mvader | ccgx:firmware_upgrade_to_v2 [2020-10-09 02:04] – [Upgrade procedure] guy_stewart | ||
====== CCGX: Upgrading to v2 ====== | ====== CCGX: Upgrading to v2 ====== | ||
- | Updating a CCGX from v1.74 to a newer version requires a one time manual upgrade. | + | ===== Introduction ===== |
+ | Updating a CCGX from v1.74 to a newer version requires a one time manual upgrade. It can’t be done automatically. | ||
- | At this moment, | + | This document explains how to do the manual upgrade. |
- | This document explains | + | Once upgraded, updates can be installed normally again. Procedure for normal firmware updates is in [[https:// |
- | Once upgraded, updates can be installed automatically from the internet again. See [[https:// | + | ===== Upgrade procedure ===== |
{{youtube> | {{youtube> | ||
Line 19: | Line 18: | ||
- | - Get a microSD card. The card needs to be formatted with either a FAT or FAT32 file system. Preferably use a card of 32GB or smaller, as larger cards are often hard to format with mentioned FAT filesystems. The upgrade requires less than 150MB on the card. | + | - Get a microSD card. The card needs to be formatted with either a FAT or FAT32 file system. Preferably use a card of 32GB or smaller, as larger cards are often hard to format with mentioned FAT file systems. The upgrade requires less than 150MB on the card. |
- Download [[https:// | - Download [[https:// | ||
- Above link always points to the latest available version. | - Above link always points to the latest available version. | ||
Line 34: | Line 33: | ||
- So, remove the card, and press buttons A and B again to reboot. | - So, remove the card, and press buttons A and B again to reboot. | ||
- | Upgrade complete | + | Upgrade |
* All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | * All settings in the connected devices (Multis, BMV, Solar Charger etcetera) won’t be affected. | ||
* Also all settings in the ccgx won’t be affected. But still it is good to double check that. | * Also all settings in the ccgx won’t be affected. But still it is good to double check that. | ||
* Especially double check wifi and/or ethernet passwords and IP configuration. | * Especially double check wifi and/or ethernet passwords and IP configuration. | ||
+ | * There are additional versions of VenusOS that have been released since this update image. To finish updating to the latest version, you can now follow the normal [[ccgx: | ||
===== Troubleshooting ===== | ===== Troubleshooting ===== | ||
- | === It restart normally and doesn' | + | === It reboots but doesn' |
- | Make sure to hold (!) button E till the upgrade starts | + | |
+ | Solution: | ||
=== A blue screen is shown while booting and after ~1 minute, " | === A blue screen is shown while booting and after ~1 minute, " | ||
Line 62: | Line 63: | ||
This means that the button pressing procedure was done OK. And the sdcard is properly formatted. | This means that the button pressing procedure was done OK. And the sdcard is properly formatted. | ||
- | Possible causes | + | Possible causes: |
- | - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard | + | |
- | - the sdcard slot in the CCGX is broken: contact your dealer for a replacement | + | |
- | ~~DISQUS~~ | + | - the .swu file is missing on the sdcard. Make sure to unzip all files on the sdcard; |
+ | - the sdcard slot in the CCGX is broken: contact your dealer for a replacement; | ||
+ | - A device, mostly a BMV or MPPT, is connected to VE.Direct port 1. Try disconnecting that, and retry. Did that help? Please let us know by posting what happened here below in Disqus. |
ccgx/firmware_upgrade_to_v2.txt · Last modified: 2021-02-08 22:30 by doc_nl
